[pgrouting-dev] windows 9.3 w64 bdstar-any.test failure
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Apr 16 07:50:40 PDT 2014
Regina,
All the tests are passing on Linux so I suspect that this is more
related to Windows.
Thank you for updating Jenkins for us. Let me know if you need help
sorting out this issue.
That error message is coming from:
src/bd_astar/src/BiDirAStar.cpp
there is a similar function
src/bd_dijkstra/src/BiDirDijkstra.cpp
that is not failing (I assume that are both getting the same test run on
them but I have not checked.)
Search for "Path Not Found", that is where the error is getting detected
and the mess is getting set.
-Steve
On 4/16/2014 3:30 AM, Paragon Corporation wrote:
> Fixed another issue with jenkins with my path changes so it wasn't testing
> the latest source.
> However after the fixing, the windows 9.3 w64 build fails one test (9.3 w32
> and 9.2s both w32/w64 are fine)
> I presume this is a new test since I don't see it in 2.0 release logs.
> Failing test is this one:
> 'doc/test/bdstar-any.test' => 'FAILED: 1,5c1
> < 0|4|3|0
> < 1|3|5|1
> < 2|6|11|1
> < 3|11|12|0
> < 4|10|-1|0
>> ERROR: Error computing path: Path Not Found',
> Does it only fail on windows 9.3 64bit? Or is this seen on other platforms.
> I presume I should be worried about it.
> Thanks,
> Regina
> --full log --
> Processing test: sampledata
> test run time: 0.750001
> Processing test: alphashape-any
> test run time: 0.439451
> Processing test: apspJohnson-any
> test run time: 0.435356
> Processing test: apspWarshall-any
> test run time: 0.428825
> Processing test: astar-any
> test run time: 0.430389
> Processing test: bdstar-any
> test run time: 0.43254
> Processing test: bdDijkstra-any
> test run time: 0.426679
> Processing test: dijkstra-any
> test run time: 0.431251
> Processing test: drivingDistance-any
> test run time: 0.427962
> Processing test: pointsAsPolygon-any
> test run time: 0.445802
> Processing test: kdijkstra-any
> test run time: 0.444671
> Processing test: tsp-any
> test run time: 0.64054
> Processing test: trsp-any
> test run time: 0.445026
> Processing test: utilities-any
> test run time: 0.429804
> Processing test: createTopology-any
> test run time: 3.390548
> Processing test: createVertTab-any
> test run time: 2.312395
> Processing test: analyzeGraph-any
> test run time: 3.406166
> Processing test: analyzeOneway-any
> test run time: 0.531148
> Processing test: nodeNetwork-any
> test run time: 1.749912
> Processing test: apsp_johnson-any-00
> test run time: 0.42163
> Processing test: apsp_warshall-any-00
> test run time: 0.433606
> Processing test: spas-any-00
> test run time: 0.426944
> Processing test: spas-any-01
> test run time: 0.428268
> Processing test: bd_astar-any-01
> test run time: 0.490152
> Processing test: bd_astar-any-02
> test run time: 0.494138
> Processing test: bd_astar-any-03
> test run time: 0.4844
> Processing test: bd_astar-any-04
> test run time: 0.484195
> Processing test: bd_astar-any-05
> test run time: 0.487583
> Processing test: bd_astar-any-06
> test run time: 0.481013
> Processing test: bd_dijkstra-any-01
> test run time: 0.483489
> Processing test: bd_dijkstra-any-02
> test run time: 0.48134
> Processing test: bd_dijkstra-any-03
> test run time: 0.487245
> Processing test: bd_dijkstra-any-04
> test run time: 0.477802
> Processing test: bd_dijkstra-any-05
> test run time: 0.475179
> Processing test: bd_dijkstra-any-06
> test run time: 0.48037
> Processing test: versionless-any-01
> test run time: 0.515625
> Processing test: common-any-01
> test run time: 0.718665
> Processing test: common-any-02
> test run time: 0.843667
> Processing test: common-any-03
> test run time: 0.765543
> Processing test: common-any-04
> test run time: 1.500003
> Processing test: common-any-05
> test run time: 0.796777
> Processing test: createTopology-any-01
> test run time: 8.703063
> Processing test: createVerticesTable-any-01
> test run time: 5.48428
> Processing test: gettablename-any-01
> test run time: 1.828011
> Processing test: pgrouting_conversion_tools-any-01
> test run time: 0.476386
> Processing test: pgrouting_dmatrix_tools-any-01
> test run time: 0.507785
> Processing test: spd-any-00
> test run time: 0.424661
> Processing test: spd-any-01
> test run time: 0.431578
> Processing test: spd-any-02
> test run time: 0.42765
> Processing test: spd-any-03
> test run time: 0.428257
> Processing test: spd-any-04
> test run time: 0.43095
> Processing test: drivingdistance-any-00
> test run time: 0.453126
> Processing test: kdijkstra-any-01
> test run time: 0.437412
> Processing test: kdijkstra-any-02
> test run time: 0.435334
> Processing test: kdijkstra-any-03
> test run time: 0.439515
> Processing test: vidstodmatrix-any-01
> test run time: 0.433029
> Processing test: vidstodmatrix-any-02
> test run time: 0.426178
> Processing test: ksp-any-01
> test run time: 0.4382
> Processing test: ksp-any-02
> test run time: 0.435956
> Processing test: trsp-any-00
> test run time: 0.430287
> Processing test: trsp-any-01
> test run time: 0.429003
> Processing test: trsp-any-02
> test run time: 0.430788
> Processing test: trsp-any-03
> test run time: 0.428426
> Processing test: trsp_vias-any-04
> test run time: 0.440013
> Processing test: trsp-issue244
> test run time: 0.434824
> Processing test: tsp-any-00
> test run time: 0.562236
> Processing test: tsp-any-01
> test run time: 0.515544
> Processing test: tsp-any-03
> test run time: 1.046802
> Processing test: tsp-any-04
> test run time: 0.49991
> Processing test: tsp-any-05
> test run time: 0.531171
> $stats = {
> 'doc/test/test.conf' => [
> 'comment' => 'documentation SQL tests
> for any versions.',
> 'doc/test/alphashape-any.test' =>
> 'Passed',
> 'doc/test/analyzeGraph-any.test' =>
> 'Passed',
> 'doc/test/analyzeOneway-any.test' =>
> 'Passed',
> 'doc/test/apspJohnson-any.test' =>
> 'Passed',
> 'doc/test/apspWarshall-any.test' =>
> 'Passed',
> 'doc/test/astar-any.test' =>
> 'Passed',
> 'doc/test/bdDijkstra-any.test' =>
> 'Passed',
> 'FAILED: 1,5c1
> < 0|4|3|0
> < 1|3|5|1
> < 2|6|11|1
> < 3|11|12|0
> < 4|10|-1|0
> 'doc/test/createTopology-any.test' =>
> 'Passed',
> 'doc/test/createVertTab-any.test' =>
> 'Passed',
> 'doc/test/dijkstra-any.test' =>
> 'Passed',
> 'doc/test/drivingDistance-any.test'
> => 'Passed',
> 'doc/test/kdijkstra-any.test' =>
> 'Passed',
> 'doc/test/nodeNetwork-any.test' =>
> 'Passed',
> 'doc/test/pointsAsPolygon-any.test'
> => 'Passed',
> 'doc/test/sampledata.test' =>
> 'Passed',
> 'doc/test/trsp-any.test' => 'Passed',
> 'doc/test/tsp-any.test' => 'Passed',
> 'doc/test/utilities-any.test' =>
> 'Passed'
> 'src/apsp_johnson/test/test.conf' => [
> 'comment' => 'APSP
> Johnson test for any versions.',
> 'src/apsp_johnson/test/apsp_johnson-any-00.test' => 'Passed'
> 'src/apsp_warshall/test/test.conf' => [
> 'comment' => 'APSP
> Warshall test for any versions.',
> 'src/apsp_warshall/test/apsp_warshall-any-00.test' => 'Passed'
> 'src/astar/test/test.conf' => [
> 'comment' => 'astar test for
> any versions.',
> 'src/astar/test/spas-any-00.test' => 'Passed',
> 'src/astar/test/spas-any-01.test' => 'Passed'
> 'src/bd_astar/test/test.conf' => [
> 'comment' => 'Bi-directional
> AStar test for any versions.',
> 'src/bd_astar/test/bd_astar-any-01.test' => 'Passed',
> 'src/bd_astar/test/bd_astar-any-02.test' => 'Passed',
> 'src/bd_astar/test/bd_astar-any-03.test' => 'Passed',
> 'src/bd_astar/test/bd_astar-any-04.test' => 'Passed',
> 'src/bd_astar/test/bd_astar-any-05.test' => 'Passed',
> 'src/bd_astar/test/bd_astar-any-06.test' => 'Passed'
> 'src/bd_dijkstra/test/test.conf' => [
> 'comment' =>
> 'Bi-directional Dijkstra test for any versions.',
> 'src/bd_dijkstra/test/bd_dijkstra-any-01.test' => 'Passed',
> 'src/bd_dijkstra/test/bd_dijkstra-any-02.test' => 'Passed',
> 'src/bd_dijkstra/test/bd_dijkstra-any-03.test' => 'Passed',
> 'src/bd_dijkstra/test/bd_dijkstra-any-04.test' => 'Passed',
> 'src/bd_dijkstra/test/bd_dijkstra-any-05.test' => 'Passed',
> 'src/bd_dijkstra/test/bd_dijkstra-any-06.test' => 'Passed'
> 'src/common/test/test.conf' => [
> 'comment' =>
> 'pgr_createTopology, pgr_analyzegraph, and pgr_analyzeOneway tests for any
> versions.',
> 'src/common/test/common-any-01.test' => 'Passed',
> 'src/common/test/common-any-02.test' => 'Passed',
> 'src/common/test/common-any-03.test' => 'Passed',
> 'src/common/test/common-any-04.test' => 'Passed',
> 'src/common/test/common-any-05.test' => 'Passed',
> 'src/common/test/createTopology-any-01.test' => 'Passed',
> 'src/common/test/createVerticesTable-any-01.test' => 'Passed',
> 'src/common/test/gettablename-any-01.test' => 'Passed',
> 'src/common/test/pgrouting_conversion_tools-any-01.test' => 'Passed',
> 'src/common/test/pgrouting_dmatrix_tools-any-01.test' => 'Passed',
> 'src/common/test/versionless-any-01.test' => 'Passed'
> 'src/dijkstra/test/test.conf' => [
> 'comment' => 'Dijkstra test
> for any versions.',
> 'src/dijkstra/test/spd-any-00.test' => 'Passed',
> 'src/dijkstra/test/spd-any-01.test' => 'Passed',
> 'src/dijkstra/test/spd-any-02.test' => 'Passed',
> 'src/dijkstra/test/spd-any-03.test' => 'Passed',
> 'src/dijkstra/test/spd-any-04.test' => 'Passed'
> 'src/driving_distance/test/test.conf' => [
> 'comment' =>
> 'Driving Distance test for any versions.',
> 'src/driving_distance/test/drivingdistance-any-00.test' => 'Passed'
> 'src/kdijkstra/test/test.conf' => [
> 'comment' => 'KDijkstra
> 'src/kdijkstra/test/kdijkstra-any-01.test' => 'Passed',
> 'src/kdijkstra/test/kdijkstra-any-02.test' => 'Passed',
> 'src/kdijkstra/test/kdijkstra-any-03.test' => 'Passed',
> 'src/kdijkstra/test/vidstodmatrix-any-01.test' => 'Passed',
> 'src/kdijkstra/test/vidstodmatrix-any-02.test' => 'Passed'
> 'src/ksp/test/test.conf' => [
> 'comment' => 'KSP test for any
> versions.',
> 'src/ksp/test/ksp-any-01.test' =>
> 'Passed',
> 'src/ksp/test/ksp-any-02.test' =>
> 'Passed'
> 'src/trsp/test/test.conf' => [
> 'comment' => 'TRSP test for any
> versions.',
> 'src/trsp/test/trsp-any-00.test'
> => 'Passed',
> 'src/trsp/test/trsp-any-01.test'
> => 'Passed',
> 'src/trsp/test/trsp-any-02.test'
> => 'Passed',
> 'src/trsp/test/trsp-any-03.test'
> => 'Passed',
> 'src/trsp/test/trsp-issue244.test' => 'Passed',
> 'src/trsp/test/trsp_vias-any-04.test' => 'Passed'
> 'src/tsp/test/test.conf' => [
> 'comment' => 'TSP test for any
> versions.',
> 'src/tsp/test/tsp-any-00.test' =>
> 'Passed',
> 'src/tsp/test/tsp-any-01.test' =>
> 'Passed',
> 'src/tsp/test/tsp-any-03.test' =>
> 'Passed',
> 'src/tsp/test/tsp-any-04.test' =>
> 'Passed',
> 'src/tsp/test/tsp-any-05.test' =>
> 'Passed'
> 'z_crash' => 0,
> 'z_fail' => 1,
> 'z_pass' => 69
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev
