[pgrouting-dev] Optimal Meeting Point (OMP)
Luís de Sousa
luis.a.de.sousa at gmail.com
Thu Dec 18 01:23:03 PST 2014
Dear all,
After various unsuccessful attempts to fix CMake I am running out of
time to pursue this little project. By some reason the Postgres types
are not being included in the OMP source folder and the compilation
fails, even if directly including the Postgres dirs.
I am shelving OMP for the moment. If anyone wishes to give it a try
please use this repo and brach:
https://github.com/ldesousa/pgrouting/tree/develop-omp
Time permitting I will return to this in the second half of 2015.
Regards and merry Christmas,
Luís
On 29 October 2014 at 17:14, Luís de Sousa <luis.a.de.sousa at gmail.com> wrote:
> Hi Stephen, thank you for your reply.
> I was missing the references to the new module in the main CMakeLists
> file (at the root). I copied the instructions from the Johnson
> algorithm as you suggested. Now I have an error message from CMake:
> CMake Error at CMakeLists.txt:263 (add_library):
> Objects of target "omp" referenced but no such target exists.
> There must be something else missing, but in the new omp folder
> structure there seem to be all the required CMakeLists files. I
> probably need to learn the basics on CMake; in the meanwhile, any
> other suggestions are welcome.
> Thank you,
> Luís
More information about the pgrouting-dev
