[pgrouting-dev] Optimal Meeting Point (OMP)
Daniel Kastl daniel at georepublic.de
Thu Dec 18 01:51:38 PST 2014
Hi Louis,
If the CMake issue is the only remaining issue, could you just create a
ticket in the pgRouting issue tracker, that we don't forget about OMP?
And maybe you can use the issue tracker of your fork to list all remaining
issues before being able to merge OMP into pgRouting. This could be for
example finishing the documentation and tests.
I think it's an interesting contribution, so if possible I would like to
have OMP part of pgRouting.
Best regards,
Daniel
On Thu, Dec 18, 2014 at 6:23 PM, Luís de Sousa <luis.a.de.sousa at gmail.com>
wrote:
> Dear all,
> After various unsuccessful attempts to fix CMake I am running out of
> time to pursue this little project. By some reason the Postgres types
> are not being included in the OMP source folder and the compilation
> fails, even if directly including the Postgres dirs.
> I am shelving OMP for the moment. If anyone wishes to give it a try
> please use this repo and brach:
> https://github.com/ldesousa/pgrouting/tree/develop-omp
> Time permitting I will return to this in the second half of 2015.
> Regards and merry Christmas,
> Luís
> On 29 October 2014 at 17:14, Luís de Sousa <luis.a.de.sousa at gmail.com>
> wrote:
> > Hi Stephen, thank you for your reply.
> > I was missing the references to the new module in the main CMakeLists
> > file (at the root). I copied the instructions from the Johnson
> > algorithm as you suggested. Now I have an error message from CMake:
> > CMake Error at CMakeLists.txt:263 (add_library):
> >   Objects of target "omp" referenced but no such target exists.
> > There must be something else missing, but in the new omp folder
> > structure there seem to be all the required CMakeLists files. I
> > probably need to learn the basics on CMake; in the meanwhile, any
> > other suggestions are welcome.
> > Thank you,
> > Luís
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.info
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20141218/3be031af/attachment.html>
More information about the pgrouting-dev mailing list
