[pgrouting-dev] [pgrouting-users] TRSP Problem
Christophe Damour
sigeal at sigeal.com
Fri Mar 7 23:06:56 PST 2014
Hi Steven,
Thank you for answering.
I double checked the topology and it looks ok.
By the way, when you say "the only way to follow the route is to go the
wrong way down a one-way street" :
Do you mean that this is the expected behaviour ?
I expected an error or an exception saying : "Path Not Found" in such a
case.
Is there a workaround for that situation or should I handle it with a
post-query process ?
Thank you again for your time.
Christophe DAMOUR
Le 07/03/2014 20:10, Stephen Woodbridge a écrit :
> Hi Christophe,
> Sorry you are having problems with this. I have a major deadline and
> have not had time to look at this. Typically the large cost value
> means that you are requesting a route and the only way to follow the
> route is to go the wrong way down a one-way street.
> This might be because you are missing some edges because your where
> clause to not including enough edges or there is some other issue with
> your graph like it is not noded correctly.
> We have supplied some tools in the 2.0 release to help node a newwork
> and to help analyze it for problems. Read the docs
> http://docs.pgrouting.org/2.0/en/doc/index.html
> Specifically the Tutorials on "Routing Topology" and Graph Analytics"
> When I have some free time, I will look at your issue, but please
> don't wait on me as it may be a while.
> Best,
> -Steve
> On 3/7/2014 1:41 PM, Christophe Damour wrote:
>> Hi,
>> No answer... I am stuck with this one.
>> Is it possible that there is a conflict between the where clause
>> processing and the cost / rev_cost ?
>> I have the same behaviour with edge start / target instead of vertex
>> start / target.
>> Here is the wrong query result :
>> seq id1 id2 cost
>> 0 19314 23805 25.2230680696244
>> 1 16327 15869 200.551744693165
>> 2 16328 30606 1000000
>> 3 22180 30607 12.1375967381755
>> 4 14374 28286 249.361944927019
>> 5 14371 18295 111.604786405456
>> 6 10776 -1 0
>> In my understanding, it shouldn't be possible to have an edge with cost
>> 1000000 in the resulting path (it is the only one in the network to have
>> such a cost, and the network is very small) !
>> Thanks for any hint,
>> Christophe DAMOUR
>> Le 03/03/2014 20:20, Christophe Damour a écrit :
>>> Hi,
>>> Sorry to post twice, I forgot the attached file...
>>> I use pgRouting to calculate accessible routes for disabled
>>> pedestrians.
>>> Network edges have some attributes that are used to filter the
>>> accessible network in both ways depending on the user capacities
>>> (where clause).
>>> Network edges have also attributes that are used to update cost /
>>> rev_cost depending on the routing way : If an edge is forbidden in the
>>> digitizing way, cost is set to 1 000 000. If it is forbidden in the
>>> reverse way, rev_cost is set to 1 000 000. If it is forbidden in both
>>> ways, cost and rev_cost are set to 1 000 000.
>>> Now, in some cases, despite there is no accessible route according to
>>> the where clause, pgr_trsp() returns a route going through edges with
>>> cost / rev_cost set to 1 000 000.
>>> If I change the where clause so that there is actually an alternative
>>> route, same edges with cost / rev_cost set to 1 000 000 are taken into
>>> account, and the calculated route is correct.
>>> I attached to this message images of both results (forbidden edges in
>>> red, returned paths in blue).
>>> Routing is calculated from edge n°18295 (vertex n°19314) to edge
>>> n°23805 (vertex n°10776).
>>> Wrong edge is n°30606 in test 2.
>>> Here is the sql code of the first test :
>>> SELECT * FROM pgr_trsp(
>>> 'SELECT id_tron::integer AS id, source::integer, target::integer,
>>> cost::double precision, rev_cost::double precision AS reverse_cost
>>> FROM rp_test
>>> WHERE type_tron NOT IN(3, 8, 9) AND largeur_c > 90 AND largeur_p > 75
>>> AND etat_revet >= 2',
>>> 19314::INTEGER, 10776::INTEGER, true, true,
>>> 'SELECT to_cost::double precision, target_id::integer, via_path::text
>>> FROM reseau_global_rest');
>>> And here is the sql code of the second test :
>>> FROM rp_test
>>> WHERE type_tron NOT IN(3, 8, 9) AND largeur_c > 90 AND largeur_p > 75',
>>> I also attach to this message a shape file of the network.
>>> Do I miss something, or is it a bug ?
>>> Thanks for any help,
>>> Christophe DAMOUR
>>> Pgrouting-users mailing list
>>> Pgrouting-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the pgrouting-dev
