[pgrouting-dev] [pgrouting-users] TRSP Problem
Stephen Woodbridge woodbri at swoodbridge.com
Sat Mar 8 08:38:22 PST 2014
On 3/8/2014 2:06 AM, Christophe Damour wrote:
> Hi Steven,
> Thank you for answering.
> I double checked the topology and it looks ok.
> By the way, when you say "the only way to follow the route is to go the
> wrong way down a one-way street" :
> Do you mean that this is the expected behaviour ?
The code is in somewhat of a transition in this regard. Historically we
could not set the cost to -1 (meaning not allowed) so users set the cost
(or reverse cost) to a large number.
I have been up dating the code as I I fix things so that it accepts
negative values and eliminates that edge from the graph so it will fail
if not route is found.
I thought TRSP already did this. so look at your data and make sure you
are not setting and costs to large values.
> I expected an error or an exception saying : "Path Not Found" in such a
> case.
> Is there a workaround for that situation or should I handle it with a
> post-query process ?
You can try to set the cost to -1 instead of a large value to eliminate
that directed edge. It should work most places but you might run into
some algorithms that do not support that and should write a bug if you
find one.
Thanks,
   -Steve
> Thank you again for your time.
More information about the pgrouting-dev mailing list
