[pgrouting-dev] [pgrouting-users] TRSP Problem SOLVED
Christophe Damour sigeal at sigeal.com
Sat Mar 8 09:35:40 PST 2014
Steven,
Thank you very much again for your time !
Setting cost to -1 indeed solved the problem, the query returning "Path
not found" as I expected.
I just wasn't aware of that option.
You and other devs do a really great work on pgRouting.
I appreciate and wish I can help in anyway.
Christophe DAMOUR
Le 08/03/2014 17:38, Stephen Woodbridge a écrit :
> On 3/8/2014 2:06 AM, Christophe Damour wrote:
>> Hi Steven,
>> Thank you for answering.
>> I double checked the topology and it looks ok.
>> By the way, when you say "the only way to follow the route is to go the
>> wrong way down a one-way street" :
>> Do you mean that this is the expected behaviour ?
> The code is in somewhat of a transition in this regard. Historically
> we could not set the cost to -1 (meaning not allowed) so users set the
> cost (or reverse cost) to a large number.
> I have been up dating the code as I I fix things so that it accepts
> negative values and eliminates that edge from the graph so it will
> fail if not route is found.
> I thought TRSP already did this. so look at your data and make sure
> you are not setting and costs to large values.
>> I expected an error or an exception saying : "Path Not Found" in such a
>> case.
>> Is there a workaround for that situation or should I handle it with a
>> post-query process ?
> You can try to set the cost to -1 instead of a large value to
> eliminate that directed edge. It should work most places but you might
> run into some algorithms that do not support that and should write a
> bug if you find one.
> Thanks,
>   -Steve
>> Thank you again for your time.
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
