[pgrouting-dev] pgr_trsp with k
Julien-Samuel Lacroix
jlacroix at mapgears.com
Tue Mar 11 07:16:48 PDT 2014
Hi Steve,
If I can look at the branch, it may give me ideas on how to do it and
what kind of problem it solve. This will probably help me define the
limits of my analysis and potential problems I may encounter.
If it does solve my problem, I will be happy to help.
Julien
On 14-03-10 09:25 PM, Stephen Woodbridge wrote:
> On 3/10/2014 8:42 PM, Julien-Samuel Lacroix wrote:
>> Hello,
>> I'm currently working with pgr_trsp. Would it be possible to get K
>> results like when we use pgr_kDijkstra?
>> I could probably provide a pull request if someone provide me some
>> pointers.
>> Julien
> Hi Julien,
> I actually have trsp code from the developer sitting in a branch that I
> have not had time to integrate, document, and setup tests for. It does
> not solve the kDijkstra problem using TRSP (but read on). I discussed
> this with Roni and he was interested in developing it. Let me know if
> you have any interest in funding Roni to do it and I'll pass on contact
> info and make introductions.
> The changes I have MIGHT be applicable to you problem. They implement
> via points so you can pass multiple location into TRSP and it will
> compute the route from 1-2-3-...-n. To do this you have to setup up the
> graph, and then reinitialize it it on the next leg of the journey. I
> think this could be adapted such that you have a start point and N
> destination and you build one graph and then solve it N times
> reinitialize the existing graph for each solution.
> Most of the cost of a solution in pgRouting is reading the edges from
> the database, passing them to the code, building the graph. The graph
> solver is fast. So if you can build one big graph then solve it N times
> it is big win.
> We would love to get a pull request for this. And if you have time to
> integrate Roni code I have not gotten to yet, that would be cool also
> and you would need it anyway.
> -Steve
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
T: +1 418-696-5056 #202
Mapgears
http://www.mapgears.com/
More information about the pgrouting-dev
