[pgrouting-dev] GSoc2014
Stephen Woodbridge woodbri at swoodbridge.com
Wed Mar 12 08:47:42 PDT 2014
On 3/12/2014 11:39 AM, Raffaello Bertini wrote:
> Well,
> I don't have any particular idea, but I'm interested to study the topics
> previously mentioned.
> Can I made more then one proposal for the contest?
Yes. we occasionally get students that submit multiple proposals.
Based on past experience, it is best to pick a subject that is of
interest and do some reading and research on that. An area that
interests you is best because it gives you the motivation to follow
through when things get tough and you will get more out of the
experience in the end.
Search google for articles on your subject and do a little research.
Discuss the ideas you have and make a proposal. We are happy to review
student proposals and make suggestions. Many candidates checkout a fork
from github and make sure they can compile it and install it locally and
read up on the wiki developer howto documents and ask questions.
Hope this helps,
   -Steve
> On Tue, Mar 11, 2014 at 2:32 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>     On 3/11/2014 6:38 AM, Raffaello Bertini wrote:
>         Hello from Italy, I'm Raffaello Bertini and I'm interested in
>         GSoc2014. I've got a bachelor degree in computer science and I'm
>         attending for the master degree, but actually I'm working for a
>         start-up designing & developing their main system. I'm finishing my
>         job at the end of April so I've been able to accomplish the
>         GSoC2014.
>         I've already worked  with GIS and routing algorithm:
>         * Postrgers/PostGIS * TSP, Dijkstra, ... * pgRouting as a fork.
>         For GSoc2014 I'm interested in these topics:
>         * *ASTP*
>         I saw there are already a pl/pgsql script that solve ATSP by
>         conversion and Simulated Annealing for solving TSP. I think it's
>         required to build a specific function inside pgRouting v2 and I have
>         in mind to develop a 3opt and/or Simulated Annealing for ATSP. Is It
>         ok?
>     Yes, the current TSP algorithm only supports symmetric TSP so an
>     Asymmetric matrix must be converted to a symmetric matrix and then
>     solved. We think it would be valuable to have an asymmetric solver.
>         * *Contraction Hierarchies*
>         I don't understand at all what it is supposed to do. Is it ask to
>         develop the Contraction Hierarchies algorithm into pgRouting or to
>         integrate the existing algorithm of OSRM?
>         Or revising the pgr2OSRM tool? (pgr2OSRM is an utility to connect
>         pgRouting to OSRM, isn't it?)
>     We originally thought it would be a good idea to support Contraction
>     Hierarchies in pgRouting. While this is still and interesting idea, I
>     needed access to a faster solver and built the osrm-tools to make a
>     bridge between Project-ORSM and pgRouting
>         * *Implement generic driving directions add-on to pgRouting*
>         This one seems very funny to do. I read the wiki "Driving Direction
>         Instructions".
>     The challenge here is to create a generic Driving Directions module
>     that will work with most any edge table and solution. We get regular
>     requests for help create Driving Directions.
>         * *Flow Algorithms*
>         Which one? Maximum or Minimun?
>         For the Maximum flow
>     I not familiar with these or what the specific requests have been in
>     the past.
>     Thank you for your interest and we look forward to your proposal. We
>     would also be happy to discuss any idea that you might be interested
>     in working on.
>     Best regards,
>        -Steve
>         Thanks. Regards Raffaello Bertini
>         _________________________________________________ pgrouting-dev
>         mailing
>         list pgrouting-dev at lists.osgeo.org
>         <mailto:pgrouting-dev at lists.osgeo.org>
>         http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev
>         <http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>     pgrouting-dev mailing list
>     pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
More information about the pgrouting-dev mailing list
