[pgrouting-dev] Optimal Meeting Point (OMP)
Luís de Sousa
luis.a.de.sousa at gmail.com
Mon Oct 27 07:32:32 PDT 2014
Dear all,
I finally found the space to tackle the OMP algorithm. I have been
going through the code of existing modules and created a new one
called omp. For now I am focusing on the integration with postgres.
However, when I compile the skeleton of this module, it does not get
past types such as FuncCallContext or TupleDesc. Apparently, at
compile time the postgres header is not being linked. I never used
CMake before, thus I suspect I am doing something wrong (the
CMakeLists file is attached).
Any guidance on this would be appreciated.
Thank you,
Luís
set(PACKAGE_SQL_FILES "")
add_subdirectory(sql)
set(PACKAGE_SQL_FILES "${PACKAGE_SQL_FILES}" PARENT_SCOPE)
subdirs(doc src test)
More information about the pgrouting-dev
