[pgrouting-dev] Reg: Compile error in KSP with PostgreSQL 8.4
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Jun 22 10:34:25 PDT 2015
Ther already is the ticket for this problem:
https://github.com/pgRouting/pgrouting/issues/301
While I'm willing to accept this is an enhancement request, it is a very
high priority in my mind because MANY production sites have to support
multiple versions of postgres and it is a standard supported feature of
postgresql to be able to run a cluster of multiple versions.
Upgrading the database is not always an option, because some software
packages require specific versions of the database and users are not
always in a position to upgrade the software dependencies. It might be
easy for a developer to do this because they are not running a
production environment, but ultimately most users that are running a
production environment, do not have this option because they go through
an IT department or a service provider and have to rely on them for
version support.
And more importantly, because it is all about me :), I can't develop and
test in my environment against 9.2, 9.3, 9.4 that I have installed when
we need to verify bugs from users, and test against versions locally.
So if Mani can get this working great, and if not I will eventually get
to it for the next release, and if we have a fix for this, I'll roll it
into develop so others that need it can get it.
-Steve
On 6/22/2015 12:25 PM, Vicky Vergara wrote:
> Steve, Mani:
> I think its a feature request, not a bug.
> I installed in a different partition the OS, and installed postgres 9.1
> and I could install pgrouting on 9.1
> So, it installs on 9.4, and 9.1 as long as they are not under the same OS.
> While the feature of "supporting multiple postgres versions on the same
> OS" is not implemented, a work around could be to migrate your databases
> from 9.1, 9.2 and 9.3 to 9.4.
> btw. issue 109 was closed by Steve and with a comment of will not fix.
> Date: Mon, 22 Jun 2015 21:20:05 +0530
> From: mani.iiit123 at gmail.com
> To: pgrouting-dev at lists.osgeo.org
> Subject: Re: [pgrouting-dev] Reg: Compile error in KSP with PostgreSQL 8.4
> Hi Steve,
> I've tried my best to update cmake/FindPostgreSQL.cmake and
> CMakeLists.txt, but the build was not successful. I've changed all the
> POSTGRES variables to 9.4, cmake executed properly, but while
> compiling(make) there is a error saying "Postgres.h" not found. Can you
> share your CMakeLists.txt and cmake/FindPostgresql..cmake. I am on the
> version 9.4.
> I think this needs to be solved for the next release. We need to the
> pass the postgresql version to build, like the option you said
> "DUSE_PG=9.x". But unfortunately it is not working right now. I'll try
> to read about cmake and see what I can do. I will update you.
> Thank you,
> Mani
> On Mon, Jun 22, 2015 at 8:20 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
> On 6/22/2015 10:37 AM, Manikanta Kondeti wrote:
> Hi,
> I am facing an error while building from source. This is that
> issue: https://github.com/pgRouting/pgrouting/issues/109
> How to resolve that? Changing Pg version to 9.1 in
> CMakeLists.txt is
> not working. I have 9.1 and 9.4 postgresql versions installed in my
> system. Help me out in resolving this.
> Mani,
> Sorry, the CMakeLists.txt files built for pgrouting 2.x were not
> designed for support multiple versions installed on the same system.
> This is a problem for me because I have 9.2, 9.3, and 9.4 installed
> and I can only build and install on 9.4.
> The solution id to update the CMakeLists.txt and specifically
> cmake/FindPostgreSQL.cmake which so you can do something like
> cd build
> cmake -DUSE_PG=9.x ..
> I took a quick look at doing this a while back but
> cmake/FindPostgreSQL.cmake needs to be replaced and other changes
> are needed and I didn't have time to make the changes and get it
> working.
> tools/test-runner.pl <http://test-runner.pl> already support options
> for pg versions and ports so only the build system is broken in this
> regard.
> If you want to read up on CMake and get this working a pull request
> would be great!
> -Steve
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> _______________________________________________ pgrouting-dev mailing
> list pgrouting-dev at lists.osgeo.org
More information about the pgrouting-dev
