[pgrouting-dev] Reg: Compile error in KSP with PostgreSQL 8.4
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Jun 22 14:46:37 PDT 2015
Try changing it to this:
# Checking POSTGRESQL_PG_CONFIG
find_program(POSTGRESQL_PG_CONFIG NAMES pg_config
PATHS
/usr/lib/postgresql/${PG_VERSION}/bin/
NO_DEFAULT_PATH
also read this:
cmake --help-command FIND_PROGRAM
-Steve
On 6/22/2015 4:43 PM, Manikanta Kondeti wrote:
> Steve,
> Thanks for the steps. I am thinking in a different method. I just
> pushed a branch cmake-postgres. In File FindPostgreSQL.cmake on line no:
> 19, PG_VERSION is a argument passed while running cmake. ( cmake
> -DPG_VERSION=9.* ).
> * Take an argument from command line.
> * Modify the present FindPostgreSQL.cmake, build it until it is working
> properly.
> I am stuck here at this point. See line no: 43 (
> COMMAND${POSTGRESQL_PG_CONFIG}--version) this is giving 8.4 as
> defaults. Therefore variables after this are set with 8.4, I need to
> somehow understand and change it.
> If you are free now we can discuss this.
> - Mani
> On Tue, Jun 23, 2015 at 1:18 AM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
> Mani wrote:
> I'm working on this already. Since this is my first time on
> cmake and
> dependencies I might need some help from you guys.
> I'll try my best to make it working.
> Start with the message below and ask where you get stuck. The steps are:
> 1. copy the FindPostgreSQL.cmake linked below to the pgrouting/cmake
> 2. this will break the build stuff because this new script sets
> different variables than the existing build expects.
> 3. sort this out and get it to build like it did before using the
> new script
> 4. when it is building like before, add the variable to set the
> version in the commandline and and use that to set
> PostgreSQL_ADDITIONAL_VERSIONS and it should work.
> Ask specific questions if you get stuck, check in your code where I
> can look at it.
> There is a ticket for this:
> https://github.com/pgRouting/pgrouting/issues/301
> -Steve
> On 6/22/2015 12:15 PM, Stephen Woodbridge wrote:
> Mani,
> You probably want to start with this version of FindPostgreSQL.cmake
> https://github.com/Kitware/CMake/blob/master/Modules/FindPostgreSQL.cmake
> It lets you specify PostgreSQL_ADDITIONAL_VERSIONS variable
> and if
> this is set to the version you want it will use this version if
> found.
> I think that the return variables that this script sets are
> different
> from what we expect in pgrouting so you might need to set the
> expected variables with the correct values also.
> So, I would replace the existing FindPostgreSQL.cmake with this
> script and then try to make it work with the existing build system,
> then look at reading a command line version and setting the variable
> above before calling find postgresql.
> -Steve
> On 6/22/2015 11:50 AM, Manikanta Kondeti wrote:
> Hi Steve,
> I've tried my best to update cmake/FindPostgreSQL.cmake and
> CMakeLists.txt, but the build was not successful. I've
> changed all
> the POSTGRES variables to 9.4, cmake executed properly, but
> while
> compiling(make) there is a error saying "Postgres.h" not
> found. Can
> you share your CMakeLists.txt and
> cmake/FindPostgresql..cmake. I am
> on the version 9.4.
> I think this needs to be solved for the next release. We need to
> the pass the postgresql version to build, like the option you
> said "DUSE_PG=9.x". But unfortunately it is not working
> right now.
> I'll try to read about cmake and see what I can do. I will
> update
> you.
> Thank you, Mani
> On Mon, Jun 22, 2015 at 8:20 PM, Stephen Woodbridge
> <mailto:woodbri at swoodbridge.com>>> wrote:
> On 6/22/2015 10:37 AM, Manikanta Kondeti wrote:
> Hi,
> I am facing an error while building from source. This is that
> issue: https://github.com/pgRouting/pgrouting/issues/109
> How to resolve that? Changing Pg version to 9.1 in
> CMakeLists.txt
> is not working. I have 9.1 and 9.4 postgresql versions
> installed in
> my system. Help me out in resolving this.
> Mani,
> Sorry, the CMakeLists.txt files built for pgrouting 2.x were not
> designed for support multiple versions installed on the same
> system. This is a problem for me because I have 9.2, 9.3,
> and 9.4
> installed and I can only build and install on 9.4.
> The solution id to update the CMakeLists.txt and specifically
> cmake/FindPostgreSQL.cmake which so you can do something like
> cd build cmake -DUSE_PG=9.x ..
> I took a quick look at doing this a while back but
> cmake/FindPostgreSQL.cmake needs to be replaced and other
> changes
> are needed and I didn't have time to make the changes and get it
> working.
> tools/test-runner.pl <http://test-runner.pl>
> <http://test-runner.pl> already support
> options for pg versions and ports so only the build system is
> broken in this regard.
> If you want to read up on CMake and get this working a pull
> request would be great!
> -Steve
> _______________________________________________ pgrouting-dev
> mailing list pgrouting-dev at lists.osgeo.org
> <mailto:pgrouting-dev at lists.osgeo.org>
> <mailto:pgrouting-dev at lists.osgeo.org>>
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> mailing
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
More information about the pgrouting-dev
