[pgrouting-dev] Reg: Compile error in KSP with PostgreSQL 8.4
Stephen Woodbridge woodbri at swoodbridge.com
Mon Jun 22 19:43:19 PDT 2015
Mani,
do you have the file: /usr/lib/postgresql/9.1/bin/pg_config on you
system? If not then you probably need to install the
postgresql-server-dev-9.1 package.
did you read "cmake --help find_program" and try other variables?
since we built and only tested on cmake 2.8 you are pretty much on your
own as I don't have cmake 3.3 installed and probably will not install it
unless we need to change the dependencies for some reason because it is
not available on Ubuntu 14.04 LTS
-Steve
On 6/22/2015 7:30 PM, Manikanta Kondeti wrote:
>   I am on version 3.3.0-rc2. I've installed the latest verion yesterday.
> Adding that NO_DEFAULT_PATH sets NULL to POSTGRESQL_PG_CONFIG and gives
> an error. I've added the screenshot.
> Why is it working on your system and not working on mine if its the same
> code..? It should find that config path. So it may be NO_DEFAULT_PATH
> not present in the latest version, will check that out.
> - Mani
> On Tue, Jun 23, 2015 at 4:37 AM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>     On 6/22/2015 6:14 PM, Manikanta Kondeti wrote:
>         Steve,
>         That's giving me an error. I understood the workflow, Here is
>         the main
>         thing that I've to look at :[line 36]  POSTGRESQL_PG_CONFIG =
>         "/usr/bin/pg_config" and that is of version 8.4.22. From this the
>     The point is that cmake is search the PATh variable and which is why
>     it is finding /usr/bin/pg_config instead of
>     The point of NO_DEFAULT_PATH argument is to prevent it from search
>     the default paths and to only look at the ones you are specifying.
>         variable POSTGRESQL_VERSION_STRING is set which makes all the
>         variables
>         in CMakeLists.txt to 8.4. This makes the whole POSTGRESQL
>         variables in
>         CMakeLists.txt to 8.4. We can see that from cmake log.
>         So if we can control this line 36 to the PG_VERSION we specify, then
>         everything works fine. I will let you know if I got something
>         interesting. I'd be highly thankful if you suggest something at
>         this point.
>     The code below works on my system. I'm using cmake version 2.8.12.2
>     cmake --version
>     I don't know when that variable was added, you probably have an
>     older version. ALSO, rm -rf build/* so you clean out the cmake
>     cache. It didn't work until I cleared it.
>     -Steve
>         - Mani
>         On Tue, Jun 23, 2015 at 3:16 AM, Stephen Woodbridge
>         <mailto:woodbri at swoodbridge.com>>> wrote:
>              Try changing it to this:
>              # Checking POSTGRESQL_PG_CONFIG
>                   find_program(POSTGRESQL_PG_CONFIG NAMES pg_config
>                       PATHS
>                       /usr/lib/postgresql/${PG_VERSION}/bin/
>                       NO_DEFAULT_PATH
>              also read this:
>              cmake --help-command FIND_PROGRAM
>              -Steve
>              On 6/22/2015 4:43 PM, Manikanta Kondeti wrote:
>                  Steve,
>                  Thanks for the steps. I am thinking in a  different
>         method. I just
>                  pushed a branch cmake-postgres. In File
>         FindPostgreSQL.cmake on
>                  line no:
>                  19, PG_VERSION is a argument passed while running
>         cmake. ( cmake
>                  -DPG_VERSION=9.* ).
>                  * Take an argument from  command line.
>                  *  Modify the present FindPostgreSQL.cmake, build it
>         until it is
>                  working
>                  properly.
>                  I am stuck here at this point.  See line no:  43 (
>                  COMMAND${POSTGRESQL_PG_CONFIG}--version)  this is
>         giving 8.4 as
>                  defaults. Therefore variables after this are set with
>         8.4, I need to
>                  somehow understand and change it.
>                  If you are free now we can discuss this.
>                  - Mani
>                  On Tue, Jun 23, 2015 at 1:18 AM, Stephen Woodbridge
>         <mailto:woodbri at swoodbridge.com> <mailto:woodbri at swoodbridge.com
>         <mailto:woodbri at swoodbridge.com>>>> wrote:
>                       Mani wrote:
>                           I'm working on this already. Since this is my
>         first time on
>                           cmake and
>                           dependencies I might need some help from you guys.
>                           I'll try my best to make it working.
>                       Start with the message below and ask where you get
>         stuck.
>                  The steps are:
>                       1. copy the FindPostgreSQL.cmake linked below to the
>                  pgrouting/cmake
>                       2. this will break the build stuff because this
>         new script sets
>                       different variables than the existing build expects.
>                       3. sort this out and get it to build like it did
>         before
>                  using the
>                       new script
>                       4. when it is building like before, add the
>         variable to set the
>                       version in the commandline and and use that to set
>                       PostgreSQL_ADDITIONAL_VERSIONS  and it should work.
>                       Ask specific questions if you get stuck, check in
>         your code
>                  where I
>                       can look at it.
>                       There is a ticket for this:
>         https://github.com/pgRouting/pgrouting/issues/301
>                       -Steve
>                       On 6/22/2015 12:15 PM, Stephen Woodbridge wrote:
>                           Mani,
>                           You probably want to start with this version of
>         https://github.com/Kitware/CMake/blob/master/Modules/FindPostgreSQL.cmake
>                             It lets you specify
>                  variable
>                           and if
>                           this is set to the version you want it will
>         use this
>                  version if
>                           found.
>                           I think that the return variables that this
>         script sets are
>                           different
>                             from what we expect in pgrouting so you
>         might need to
>                  set the
>                           expected variables with the correct values also.
>                           So, I would replace the existing
>                  with this
>                           script and then try to make it work with the
>         existing
>                  build system,
>                           then look at reading a command line version
>         and setting
>                  the variable
>                           above before calling find postgresql.
>                           -Steve
>                           On 6/22/2015 11:50 AM, Manikanta Kondeti wrote:
>                               Hi Steve,
>                               I've tried my best to update
>                  cmake/FindPostgreSQL.cmake  and
>                               CMakeLists.txt, but the build was not
>         successful. I've
>                               changed all
>                               the POSTGRES variables to 9.4, cmake executed
>                  properly, but
>                               while
>                               compiling(make) there is a error saying
>                  "Postgres.h" not
>                               found. Can
>                               you share your CMakeLists.txt and
>                               cmake/FindPostgresql..cmake. I am
>                               on the version 9.4.
>                               I think this needs to be solved for the next
>                  release. We need to
>                               the pass the postgresql version to build,
>         like the
>                  option you
>                               said "DUSE_PG=9.x". But unfortunately it
>         is not working
>                               right now.
>                               I'll try to read about cmake and see what
>         I can do.
>                  I will
>                               update
>                               you.
>                               Thank you, Mani
>                               On Mon, Jun 22, 2015 at 8:20 PM, Stephen
>         Woodbridge
>         <mailto:woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>
>         <mailto:woodbri at swoodbridge.com>>>>> wrote:
>                               On 6/22/2015 10:37 AM, Manikanta Kondeti
>         wrote:
>                               Hi,
>                               I am facing an error while building from
>         source.
>                  This is that
>                               issue:
>         https://github.com/pgRouting/pgrouting/issues/109
>                               How to resolve that?  Changing Pg version
>         to 9.1 in
>                               CMakeLists.txt
>                               is not working. I have 9.1 and 9.4
>         postgresql versions
>                               installed in
>                               my system. Help me out in resolving this.
>                               Mani,
>                               Sorry, the CMakeLists.txt files built for
>         pgrouting
>                  2.x were not
>                               designed for support multiple versions
>         installed on
>                  the same
>                               system. This is a problem for me because I
>         have
>                  9.2, 9.3,
>                               and 9.4
>                               installed and I can only build and install
>         on 9.4.
>                               The solution id to update the
>         CMakeLists.txt and
>                  specifically
>                               cmake/FindPostgreSQL.cmake which so you can do
>                  something like
>                               cd build cmake -DUSE_PG=9.x ..
>                               I took a quick look at doing this a while
>         back but
>                               cmake/FindPostgreSQL.cmake needs to be
>         replaced and
>                  other
>                               changes
>                               are needed and I didn't have time to make the
>                  changes and get it
>                               working.
>                               tools/test-runner.pl
>         <http://test-runner.pl> <http://test-runner.pl>
>                               <http://test-runner.pl> already support
>                               options for pg versions and ports so only
>         the build
>                  system is
>                               broken in this regard.
>                               If you want to read up on CMake and get this
>                  working a pull
>                               request would be great!
>                               -Steve
>           _______________________________________________
>                  pgrouting-dev
>                               mailing list pgrouting-dev at lists.osgeo.org
>         <mailto:pgrouting-dev at lists.osgeo.org>
>         <mailto:pgrouting-dev at lists.osgeo.org>>
>         <mailto:pgrouting-dev at lists.osgeo.org>>>
>         <mailto:pgrouting-dev at lists.osgeo.org>>>>
>         http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>                  pgrouting-dev
>                  pgrouting-dev
>                           mailing
>                       pgrouting-dev mailing list
>         pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
More information about the pgrouting-dev mailing list
