[pgrouting-dev] Reg: Compile error in KSP with PostgreSQL 8.4
Manikanta Kondeti
mani.iiit123 at gmail.com
Tue Jun 23 01:34:25 PDT 2015
Steve,
Thanks for pointing that out. I haven't installed postgresql-server-dev-9.*
(bummer). Anyway I pushed the latest code and build is successful. Here is
the command to specify a version.
* cmake -DPG_VERSION="9.4" -Wno-dev ..
PG_VERSION=["8.4","9.* "], Wno-dev=Ignore warnings.
I think this solves the issue 301? We can specify this details near the
issue. I will start reading about "cmake --help find_program", I totally
understand what we did. But is it a simple hack or working solution?
- Mani
On Tue, Jun 23, 2015 at 8:13 AM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> Mani,
> do you have the file: /usr/lib/postgresql/9.1/bin/pg_config on you system?
> If not then you probably need to install the postgresql-server-dev-9.1
> package.
> did you read "cmake --help find_program" and try other variables?
> since we built and only tested on cmake 2.8 you are pretty much on your
> own as I don't have cmake 3.3 installed and probably will not install it
> unless we need to change the dependencies for some reason because it is not
> available on Ubuntu 14.04 LTS
> -Steve
> On 6/22/2015 7:30 PM, Manikanta Kondeti wrote:
>> I am on version 3.3.0-rc2. I've installed the latest verion yesterday.
>> Adding that NO_DEFAULT_PATH sets NULL to POSTGRESQL_PG_CONFIG and gives
>> an error. I've added the screenshot.
>> Why is it working on your system and not working on mine if its the same
>> code..? It should find that config path. So it may be NO_DEFAULT_PATH
>> not present in the latest version, will check that out.
>> - Mani
>> On Tue, Jun 23, 2015 at 4:37 AM, Stephen Woodbridge
>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>> On 6/22/2015 6:14 PM, Manikanta Kondeti wrote:
>> Steve,
>> That's giving me an error. I understood the workflow, Here is
>> the main
>> thing that I've to look at :[line 36] POSTGRESQL_PG_CONFIG =
>> "/usr/bin/pg_config" and that is of version 8.4.22. From this the
>> The point is that cmake is search the PATh variable and which is why
>> it is finding /usr/bin/pg_config instead of
>> The point of NO_DEFAULT_PATH argument is to prevent it from search
>> the default paths and to only look at the ones you are specifying.
>> variable POSTGRESQL_VERSION_STRING is set which makes all the
>> variables
>> in CMakeLists.txt to 8.4. This makes the whole POSTGRESQL
>> variables in
>> CMakeLists.txt to 8.4. We can see that from cmake log.
>> So if we can control this line 36 to the PG_VERSION we specify,
>> then
>> everything works fine. I will let you know if I got something
>> interesting. I'd be highly thankful if you suggest something at
>> this point.
>> The code below works on my system. I'm using cmake version 2.8.12.2
>> cmake --version
>> I don't know when that variable was added, you probably have an
>> older version. ALSO, rm -rf build/* so you clean out the cmake
>> cache. It didn't work until I cleared it.
>> -Steve
>> - Mani
>> On Tue, Jun 23, 2015 at 3:16 AM, Stephen Woodbridge
>> <mailto:woodbri at swoodbridge.com>>> wrote:
>> Try changing it to this:
>> # Checking POSTGRESQL_PG_CONFIG
>> find_program(POSTGRESQL_PG_CONFIG NAMES pg_config
>> PATHS
>> /usr/lib/postgresql/${PG_VERSION}/bin/
>> NO_DEFAULT_PATH
>> also read this:
>> cmake --help-command FIND_PROGRAM
>> -Steve
>> On 6/22/2015 4:43 PM, Manikanta Kondeti wrote:
>> Steve,
>> Thanks for the steps. I am thinking in a different
>> method. I just
>> pushed a branch cmake-postgres. In File
>> FindPostgreSQL.cmake on
>> line no:
>> 19, PG_VERSION is a argument passed while running
>> cmake. ( cmake
>> -DPG_VERSION=9.* ).
>> * Take an argument from command line.
>> * Modify the present FindPostgreSQL.cmake, build it
>> until it is
>> working
>> properly.
>> I am stuck here at this point. See line no: 43 (
>> COMMAND${POSTGRESQL_PG_CONFIG}--version) this is
>> giving 8.4 as
>> defaults. Therefore variables after this are set with
>> 8.4, I need to
>> somehow understand and change it.
>> If you are free now we can discuss this.
>> - Mani
>> On Tue, Jun 23, 2015 at 1:18 AM, Stephen Woodbridge
>> <mailto:woodbri at swoodbridge.com> <mailto:woodbri at swoodbridge.com
>> <mailto:woodbri at swoodbridge.com>>>> wrote:
>> Mani wrote:
>> I'm working on this already. Since this is my
>> first time on
>> cmake and
>> dependencies I might need some help from you
>> guys.
>> I'll try my best to make it working.
>> Start with the message below and ask where you get
>> stuck.
>> The steps are:
>> 1. copy the FindPostgreSQL.cmake linked below to the
>> pgrouting/cmake
>> 2. this will break the build stuff because this
>> new script sets
>> different variables than the existing build expects.
>> 3. sort this out and get it to build like it did
>> before
>> using the
>> new script
>> 4. when it is building like before, add the
>> variable to set the
>> version in the commandline and and use that to set
>> PostgreSQL_ADDITIONAL_VERSIONS and it should work.
>> Ask specific questions if you get stuck, check in
>> your code
>> where I
>> can look at it.
>> There is a ticket for this:
>> https://github.com/pgRouting/pgrouting/issues/301
>> -Steve
>> On 6/22/2015 12:15 PM, Stephen Woodbridge wrote:
>> Mani,
>> You probably want to start with this version of
>> https://github.com/Kitware/CMake/blob/master/Modules/FindPostgreSQL.cmake
>> It lets you specify
>> variable
>> and if
>> this is set to the version you want it will
>> use this
>> version if
>> found.
>> I think that the return variables that this
>> script sets are
>> different
>> from what we expect in pgrouting so you
>> might need to
>> set the
>> expected variables with the correct values also.
>> So, I would replace the existing
>> with this
>> script and then try to make it work with the
>> existing
>> build system,
>> then look at reading a command line version
>> and setting
>> the variable
>> above before calling find postgresql.
>> -Steve
>> On 6/22/2015 11:50 AM, Manikanta Kondeti wrote:
>> Hi Steve,
>> I've tried my best to update
>> cmake/FindPostgreSQL.cmake and
>> CMakeLists.txt, but the build was not
>> successful. I've
>> changed all
>> the POSTGRES variables to 9.4, cmake
>> executed
>> properly, but
>> while
>> compiling(make) there is a error saying
>> "Postgres.h" not
>> found. Can
>> you share your CMakeLists.txt and
>> cmake/FindPostgresql..cmake. I am
>> on the version 9.4.
>> I think this needs to be solved for the next
>> release. We need to
>> the pass the postgresql version to build,
>> like the
>> option you
>> said "DUSE_PG=9.x". But unfortunately it
>> is not working
>> right now.
>> I'll try to read about cmake and see what
>> I can do.
>> I will
>> update
>> you.
>> Thank you, Mani
>> On Mon, Jun 22, 2015 at 8:20 PM, Stephen
>> Woodbridge
>> <mailto:woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>
>> <mailto:woodbri at swoodbridge.com>>>>> wrote:
>> On 6/22/2015 10:37 AM, Manikanta Kondeti
>> wrote:
>> Hi,
>> I am facing an error while building from
>> source.
>> This is that
>> issue:
>> https://github.com/pgRouting/pgrouting/issues/109
>> How to resolve that? Changing Pg version
>> to 9.1 in
>> CMakeLists.txt
>> is not working. I have 9.1 and 9.4
>> postgresql versions
>> installed in
>> my system. Help me out in resolving this.
>> Mani,
>> Sorry, the CMakeLists.txt files built for
>> pgrouting
>> 2.x were not
>> designed for support multiple versions
>> installed on
>> the same
>> system. This is a problem for me because I
>> have
>> 9.2, 9.3,
>> and 9.4
>> installed and I can only build and install
>> on 9.4.
>> The solution id to update the
>> CMakeLists.txt and
>> specifically
>> cmake/FindPostgreSQL.cmake which so you can
>> do
>> something like
>> cd build cmake -DUSE_PG=9.x ..
>> I took a quick look at doing this a while
>> back but
>> cmake/FindPostgreSQL.cmake needs to be
>> replaced and
>> other
>> changes
>> are needed and I didn't have time to make
>> the
>> changes and get it
>> working.
>> tools/test-runner.pl
>> <http://test-runner.pl> <http://test-runner.pl>
>> <http://test-runner.pl> already support
>> options for pg versions and ports so only
>> the build
>> system is
>> broken in this regard.
>> If you want to read up on CMake and get this
>> working a pull
>> request would be great!
>> -Steve
>> pgrouting-dev
>> mailing list pgrouting-dev at lists.osgeo.org
>> <mailto:pgrouting-dev at lists.osgeo.org>
>> <mailto:pgrouting-dev at lists.osgeo.org>>
>> <mailto:pgrouting-dev at lists.osgeo.org>>>
>> <mailto:pgrouting-dev at lists.osgeo.org>>>>
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>> pgrouting-dev
>> pgrouting-dev
>> mailing
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org <mailto:
>> pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20150623/48a0d161/attachment-0001.html>
More information about the pgrouting-dev
