[pgrouting-dev] pgRoutingLayer QGIS3 version
Cayetano Benavent cayetano.benavent at geographica.gs
Wed Oct 10 01:09:54 PDT 2018
Hi all,
I have merged PR#82 <https://github.com/pgRouting/pgRoutingLayer/pull/82>
and published the new pre-release "v3.0.0-alpha1":
https://github.com/pgRouting/pgRoutingLayer/releases/tag/v3.0.0-alpha1
I know we need to do more work but I have little time and I think priority
is to have a QGIS3 version to share with community.
More things: I would like to update the Readme file because it is totally
outdated.
Thanks!
*Cayetano Benavent*Head of Data
+34 954 095 876
www.geographica.gs
El jue., 4 oct. 2018 a las 12:44, Cayetano Benavent (<
cayetano.benavent at geographica.gs>) escribió:
> Hi all,
> Works I have done:
> - I've updated develop branch because it was very outdated (now is paired
> with master).
> - I've changed base branch (now is develop) for PR to merge all the works
> for QGIS3 version: https://github.com/pgRouting/pgRoutingLayer/pull/82
> - I've created "gsoc2018" tag with all the works derived from GSOC 2018 by
> Aasheesh Tiwari past summer:
> https://github.com/pgRouting/pgRoutingLayer/tree/gsoc2018
> In several days we remove python3 branch, we will merge PR#82
> <https://github.com/pgRouting/pgRoutingLayer/pull/82> and we will
> create v3.0.0-alpha1 version (without pgr_DijkstraCost).
> Regarding to DijkstraCost function, I will try to review it again to
> include in v3.0.0-alpha2 version (now I understand his utility in QGIS :) ).
> It is important understand several things to do a better planning of
> pgRoutingLayer future:
> - QGIS2 is developed entirely with Python 2.
> - QGIS3 is developed entirely with Python 3 and PyQGIS API is very
> different to QGIS2.
> - Python 2 EOL (end of life) is very near (Python 2 will be retired in 1
> year) (https://pythonclock.org/ and
> https://www.python.org/dev/peps/pep-0373/).
> Taking in consideration this information we should not spend time to code
> in Python 2 so we only can develop in one direction: QGIS3.
> Last pgRoutingLayer version for QGIS2 should be 2.2 (actually this is the
> last version uploaded to QGIS plugin hub).
> QGIS3 is very (very) superior to QGIS2 (most of his core has been
> rewrited) so if you can migrate version (2 to 3) you should do. I can help
> you if you do not know how to migrate version (it is very easy in all
> operative systems).
> We are very near to have a QGIS3 version!
> Regards,
> +34 954 095 876
> www.geographica.gs
> El mié., 3 oct. 2018 a las 17:01, Vicky Vergara (<vicky at georepublic.de>)
> escribió:
>> Hi Cayetano
>> Please Merge first the branch to "develop" branch.
>> And clean the repository
>> send a mail to this list about the branches that will be deleted,
>> wait 3 or 4 days for people to double check that no "important" work will
>> be deleted.
>> Make sure that the tag that contains the GSoC students work was created.
>> (and the tag has as last commit, the last commit of the student during
>> the program)
>> I really don't remember if I taged his work, we never continue work on a
>> students branch,
>> that branch has to remain intact when the GoC program is over that
>> contains the students work and his work only.
>> By cleaning the repo:
>> When people clone or update their fork, they would only get master and
>> develop branch.
>> master has pgRoutingLayer v2.2.0 and branch develop has v3.0.0-dev
>> Because the version is a "major" change  we have to go thru the following
>> phases:
>> v3.0.0-alpha (v3.0.0-alpha1 if needed see bellow)
>> v3.0.0-beta
>> v3.0.0-rc
>> etc.
>> Use that versioning numbering to create the following branches & tags
>> v3.0.0-alpha1  Includes all the functions that are coded
>> v3.0.0-alpha2  Remove function(s) that is(are)  well-known to have issues
>> (issues must be documented on the issue list)
>> or
>> v3.0.0-alpha Include only the functions that supposedly work well
>> or
>> v3.0.0-alpha1 Includes only pgr_dijkstra
>> v3.0.0-alpha2 Includes also pgr_dijkstraCost
>> etc ...
>> I like third option best because also work on documentation has to be
>> done.
>> So make users documentation of pgr_dijkstra and make the alpha with only
>> that function
>> So gradually documentation and functionality come in an alpha
>> I know version pgRoutingLayer v3.0.0 will use python3 what I dont know,
>> is which versions of QGIS it will work.
>> The version v2.0 didn't handle the functions with the "pgr_" is that
>> going to remain the same?
>> Which versions of pgRouting  will it work with?
>> I guess you removed all the deprecated functions, so for example, and
>> kept for example
>> for 2.1: pgr_dijkstra, pgr_drivingDistance and pgr_KSP
>> Maybe, many users (like me) have QGIS 2.18
>> Some instructions about testing the phases would be needed.
>> About initial decisions of what can be included:
>> Now that we are starting a new major
>> one thing is I learned is don't include what does not work
>> In our case, besides pgRoutingLayer code correctness, we depend on the
>> correctness of pgRouting :
>> About withPoints & all proposed functions
>> https://docs.pgrouting.org/2.6/en/proposed.html#stable
>> There is a warning. and some detected issues:
>> https://github.com/pgRouting/pgrouting/issues?q=is%3Aopen+is%3Aissue+label%3AwithPoints
>> About experimental functions:
>> https://docs.pgrouting.org/2.6/en/proposed.html#experimental-functions
>> About pgr_dijkstraCost in QGiS I use it (to generate the image) here:
>> https://workshop.pgrouting.org/2.5.0/en/chapters/shortest_path.html#exercise-5-many-pedestrians-going-to-different-destinations-returning-aggregate-costs
>> compare VS
>> https://workshop.pgrouting.org/2.5.0/en/chapters/shortest_path.html#exercise-4-many-pedestrians-going-to-different-destinations
>> It gives a different perspective of the results of pgr_dijkstra
>> As reference:
>> This is the latest pgRouting documentation
>> https://docs.pgrouting.org/2.6/en/index.htm
>> This is the pgRouting 3.0.0-dev documentation (to be released on
>> September 2019)
>> https://docs.pgrouting.org/dev/en/index.html
>> Lots of things to plan
>> Regards
>> Vicky
>> On Tue, Oct 2, 2018 at 7:32 PM Cayetano Benavent <
>> cayetano.benavent at geographica.gs> wrote:
>>> Hi all,
>>> I have finally cleaned code and fixed last bugs in python3 branch from
>>> pgRoutingLayer with all the work done by student Aasheesh Tiwari
>>> (@AasheeshT) this summer in GSOC.
>>> I would like to merge python3 branch with master and upload a QGIS3
>>> version. I've tested this code and it is working well in QGIS3 although
>>> there is still a lot of work to do :)
>>> It is important to note that I've removed several functions (what I
>>> really did is comment access from GUI):
>>> - WithPoints family: these functions don't work well because they were a
>>> very last addition in GSOC. We will add this code when Aasheesh (or
>>> somebody) fixes them.
>>> - TSP euclidean: This function is not working properly (before GSOC this
>>> function does not work well). I think is more useful to add pgr_TSP in the
>>> future that fix euclidean version.
>>> - DijkstraCost: This function is not working properly and I don't
>>> undestand very well the purpose of this function in QGIS.
>>> Deprecated functions were also removed (kdijkstra_path
>>> and kdijkstra_cost) but in this case we removed all the code.
>>> Thanks,
>>> +34 954 095 876
>>> www.geographica.gs
>>> pgrouting-dev mailing list
>>> pgrouting-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>> Georepublic UG (haftungsbeschränkt)
>> Salzmannstraße 44,
>> 81739 München, Germany
>> Vicky Vergara
>> Operations Research
>> eMail: vicky at georepublic.de
>> Web: https://georepublic.info
>> Tel: +49 (089) 4161 7698-1
>> Fax: +49 (089) 4161 7698-9
>> Commercial register: Amtsgericht München, HRB 181428
>> CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20181010/1e6ee357/attachment-0001.html>
More information about the pgrouting-dev mailing list
