[pgrouting-dev] pgRoutingLayer QGIS3 version
Cayetano Benavent
cayetano.benavent at geographica.gs
Thu Oct 4 03:44:07 PDT 2018
Hi all,
Works I have done:
- I've updated develop branch because it was very outdated (now is paired
with master).
- I've changed base branch (now is develop) for PR to merge all the works
for QGIS3 version: https://github.com/pgRouting/pgRoutingLayer/pull/82
- I've created "gsoc2018" tag with all the works derived from GSOC 2018 by
Aasheesh Tiwari past summer:
https://github.com/pgRouting/pgRoutingLayer/tree/gsoc2018
In several days we remove python3 branch, we will merge PR#82
<https://github.com/pgRouting/pgRoutingLayer/pull/82> and we will
create v3.0.0-alpha1 version (without pgr_DijkstraCost).
Regarding to DijkstraCost function, I will try to review it again to
include in v3.0.0-alpha2 version (now I understand his utility in QGIS :) ).
It is important understand several things to do a better planning of
pgRoutingLayer future:
- QGIS2 is developed entirely with Python 2.
- QGIS3 is developed entirely with Python 3 and PyQGIS API is very
different to QGIS2.
- Python 2 EOL (end of life) is very near (Python 2 will be retired in 1
year) (https://pythonclock.org/ and
https://www.python.org/dev/peps/pep-0373/).
Taking in consideration this information we should not spend time to code
in Python 2 so we only can develop in one direction: QGIS3.
Last pgRoutingLayer version for QGIS2 should be 2.2 (actually this is the
last version uploaded to QGIS plugin hub).
QGIS3 is very (very) superior to QGIS2 (most of his core has been rewrited)
so if you can migrate version (2 to 3) you should do. I can help you if you
do not know how to migrate version (it is very easy in all operative
systems).
We are very near to have a QGIS3 version!
Regards,
*Cayetano Benavent*Head of Data
+34 954 095 876
www.geographica.gs
El mié., 3 oct. 2018 a las 17:01, Vicky Vergara (<vicky at georepublic.de>)
escribió:
> Hi Cayetano
> Please Merge first the branch to "develop" branch.
> And clean the repository
> send a mail to this list about the branches that will be deleted,
> wait 3 or 4 days for people to double check that no "important" work will
> be deleted.
> Make sure that the tag that contains the GSoC students work was created.
> (and the tag has as last commit, the last commit of the student during the
> program)
> I really don't remember if I taged his work, we never continue work on a
> students branch,
> that branch has to remain intact when the GoC program is over that
> contains the students work and his work only.
> By cleaning the repo:
> When people clone or update their fork, they would only get master and
> develop branch.
> master has pgRoutingLayer v2.2.0 and branch develop has v3.0.0-dev
> Because the version is a "major" change we have to go thru the following
> phases:
> v3.0.0-alpha (v3.0.0-alpha1 if needed see bellow)
> v3.0.0-beta
> v3.0.0-rc
> etc.
> Use that versioning numbering to create the following branches & tags
> v3.0.0-alpha1 Includes all the functions that are coded
> v3.0.0-alpha2 Remove function(s) that is(are) well-known to have issues
> (issues must be documented on the issue list)
> or
> v3.0.0-alpha Include only the functions that supposedly work well
> or
> v3.0.0-alpha1 Includes only pgr_dijkstra
> v3.0.0-alpha2 Includes also pgr_dijkstraCost
> etc ...
> I like third option best because also work on documentation has to be done.
> So make users documentation of pgr_dijkstra and make the alpha with only
> that function
> So gradually documentation and functionality come in an alpha
> I know version pgRoutingLayer v3.0.0 will use python3 what I dont know, is
> which versions of QGIS it will work.
> The version v2.0 didn't handle the functions with the "pgr_" is that going
> to remain the same?
> Which versions of pgRouting will it work with?
> I guess you removed all the deprecated functions, so for example, and kept
> for example
> for 2.1: pgr_dijkstra, pgr_drivingDistance and pgr_KSP
> Maybe, many users (like me) have QGIS 2.18
> Some instructions about testing the phases would be needed.
> About initial decisions of what can be included:
> Now that we are starting a new major
> one thing is I learned is don't include what does not work
> In our case, besides pgRoutingLayer code correctness, we depend on the
> correctness of pgRouting :
> About withPoints & all proposed functions
> https://docs.pgrouting.org/2.6/en/proposed.html#stable
> There is a warning. and some detected issues:
> https://github.com/pgRouting/pgrouting/issues?q=is%3Aopen+is%3Aissue+label%3AwithPoints
> About experimental functions:
> https://docs.pgrouting.org/2.6/en/proposed.html#experimental-functions
> About pgr_dijkstraCost in QGiS I use it (to generate the image) here:
> https://workshop.pgrouting.org/2.5.0/en/chapters/shortest_path.html#exercise-5-many-pedestrians-going-to-different-destinations-returning-aggregate-costs
> compare VS
> https://workshop.pgrouting.org/2.5.0/en/chapters/shortest_path.html#exercise-4-many-pedestrians-going-to-different-destinations
> It gives a different perspective of the results of pgr_dijkstra
> As reference:
> This is the latest pgRouting documentation
> https://docs.pgrouting.org/2.6/en/index.htm
> This is the pgRouting 3.0.0-dev documentation (to be released on September
> 2019)
> https://docs.pgrouting.org/dev/en/index.html
> Lots of things to plan
> Regards
> Vicky
> On Tue, Oct 2, 2018 at 7:32 PM Cayetano Benavent <
> cayetano.benavent at geographica.gs> wrote:
>> Hi all,
>> I have finally cleaned code and fixed last bugs in python3 branch from
>> pgRoutingLayer with all the work done by student Aasheesh Tiwari
>> (@AasheeshT) this summer in GSOC.
>> I would like to merge python3 branch with master and upload a QGIS3
>> version. I've tested this code and it is working well in QGIS3 although
>> there is still a lot of work to do :)
>> It is important to note that I've removed several functions (what I
>> really did is comment access from GUI):
>> - WithPoints family: these functions don't work well because they were a
>> very last addition in GSOC. We will add this code when Aasheesh (or
>> somebody) fixes them.
>> - TSP euclidean: This function is not working properly (before GSOC this
>> function does not work well). I think is more useful to add pgr_TSP in the
>> future that fix euclidean version.
>> - DijkstraCost: This function is not working properly and I don't
>> undestand very well the purpose of this function in QGIS.
>> Deprecated functions were also removed (kdijkstra_path
>> and kdijkstra_cost) but in this case we removed all the code.
>> Thanks,
>> +34 954 095 876
>> www.geographica.gs
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> Georepublic UG (haftungsbeschränkt)
> Salzmannstraße 44,
> 81739 München, Germany
> Vicky Vergara
> Operations Research
> eMail: vicky at georepublic.de
> Web: https://georepublic.info
> Tel: +49 (089) 4161 7698-1
> Fax: +49 (089) 4161 7698-9
> Commercial register: Amtsgericht München, HRB 181428
> CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20181004/9e87ac6a/attachment-0001.html>
More information about the pgrouting-dev
