[pgrouting-dev] pgRoutingLayer QGIS3 version
Cayetano Benavent
cayetano.benavent at geographica.gs
Thu Oct 11 10:06:40 PDT 2018
Hi Vicky,
Python has several linters. I propose to use for pgRoutingLayer project
this tool: PyLint (http://pylint.pycqa.org). PyLynt is mantained by Python
Code Quality Authority (http://meta.pycqa.org). I need to prepare and
include a configuration file (.pylintrc) in repository.
To test this new release I will write a wiki explaining how can you do it.
Thanks,
*Cayetano Benavent*Head of Data
+34 954 095 876
www.geographica.gs
El mié., 10 oct. 2018 a las 15:44, Vicky Vergara (<vicky at georepublic.de>)
escribió:
> Hi Cayetano
> Does python has some sort of code linter?
> Would be nice to lint the code and set some standards,
> like use spaces instead of tabs, how many spaces, etc.
> I am not a python expert but for C++ I use googles linter:
> https://github.com/cpplint/cpplint
> BTW, what do I have to do to test the the release?
> Regards Vicky
> On Wed, Oct 10, 2018 at 3:10 AM Cayetano Benavent <
> cayetano.benavent at geographica.gs> wrote:
>> Hi all,
>> I have merged PR#82 <https://github.com/pgRouting/pgRoutingLayer/pull/82>
>> and published the new pre-release "v3.0.0-alpha1":
>> https://github.com/pgRouting/pgRoutingLayer/releases/tag/v3.0.0-alpha1
>> I know we need to do more work but I have little time and I think
>> priority is to have a QGIS3 version to share with community.
>> More things: I would like to update the Readme file because it is totally
>> outdated.
>> Thanks!
>> +34 954 095 876
>> www.geographica.gs
>> El jue., 4 oct. 2018 a las 12:44, Cayetano Benavent (<
>> cayetano.benavent at geographica.gs>) escribió:
>>> Hi all,
>>> Works I have done:
>>> - I've updated develop branch because it was very outdated (now is
>>> paired with master).
>>> - I've changed base branch (now is develop) for PR to merge all the
>>> works for QGIS3 version:
>>> - I've created "gsoc2018" tag with all the works derived from GSOC 2018
>>> by Aasheesh Tiwari past summer:
>>> https://github.com/pgRouting/pgRoutingLayer/tree/gsoc2018
>>> In several days we remove python3 branch, we will merge PR#82
>>> <https://github.com/pgRouting/pgRoutingLayer/pull/82> and we will
>>> create v3.0.0-alpha1 version (without pgr_DijkstraCost).
>>> Regarding to DijkstraCost function, I will try to review it again to
>>> include in v3.0.0-alpha2 version (now I understand his utility in QGIS :) ).
>>> It is important understand several things to do a better planning of
>>> pgRoutingLayer future:
>>> - QGIS2 is developed entirely with Python 2.
>>> - QGIS3 is developed entirely with Python 3 and PyQGIS API is very
>>> different to QGIS2.
>>> - Python 2 EOL (end of life) is very near (Python 2 will be retired in 1
>>> year) (https://pythonclock.org/ and
>>> https://www.python.org/dev/peps/pep-0373/).
>>> Taking in consideration this information we should not spend time to
>>> code in Python 2 so we only can develop in one direction: QGIS3.
>>> Last pgRoutingLayer version for QGIS2 should be 2.2 (actually this is
>>> the last version uploaded to QGIS plugin hub).
>>> QGIS3 is very (very) superior to QGIS2 (most of his core has been
>>> rewrited) so if you can migrate version (2 to 3) you should do. I can help
>>> you if you do not know how to migrate version (it is very easy in all
>>> operative systems).
>>> We are very near to have a QGIS3 version!
>>> Regards,
>>> +34 954 095 876
>>> www.geographica.gs
>>> El mié., 3 oct. 2018 a las 17:01, Vicky Vergara (<vicky at georepublic.de>)
>>> escribió:
>>>> Hi Cayetano
>>>> Please Merge first the branch to "develop" branch.
>>>> And clean the repository
>>>> send a mail to this list about the branches that will be deleted,
>>>> wait 3 or 4 days for people to double check that no "important" work
>>>> will be deleted.
>>>> Make sure that the tag that contains the GSoC students work was
>>>> created.
>>>> (and the tag has as last commit, the last commit of the student during
>>>> the program)
>>>> I really don't remember if I taged his work, we never continue work on
>>>> a students branch,
>>>> that branch has to remain intact when the GoC program is over that
>>>> contains the students work and his work only.
>>>> By cleaning the repo:
>>>> When people clone or update their fork, they would only get master and
>>>> develop branch.
>>>> master has pgRoutingLayer v2.2.0 and branch develop has v3.0.0-dev
>>>> Because the version is a "major" change we have to go thru the
>>>> following phases:
>>>> v3.0.0-alpha (v3.0.0-alpha1 if needed see bellow)
>>>> v3.0.0-beta
>>>> v3.0.0-rc
>>>> etc.
>>>> Use that versioning numbering to create the following branches & tags
>>>> v3.0.0-alpha1 Includes all the functions that are coded
>>>> v3.0.0-alpha2 Remove function(s) that is(are) well-known to have
>>>> issues (issues must be documented on the issue list)
>>>> or
>>>> v3.0.0-alpha Include only the functions that supposedly work well
>>>> or
>>>> v3.0.0-alpha1 Includes only pgr_dijkstra
>>>> v3.0.0-alpha2 Includes also pgr_dijkstraCost
>>>> etc ...
>>>> I like third option best because also work on documentation has to be
>>>> done.
>>>> So make users documentation of pgr_dijkstra and make the alpha with
>>>> only that function
>>>> So gradually documentation and functionality come in an alpha
>>>> I know version pgRoutingLayer v3.0.0 will use python3 what I dont know,
>>>> is which versions of QGIS it will work.
>>>> The version v2.0 didn't handle the functions with the "pgr_" is that
>>>> going to remain the same?
>>>> Which versions of pgRouting will it work with?
>>>> I guess you removed all the deprecated functions, so for example, and
>>>> kept for example
>>>> for 2.1: pgr_dijkstra, pgr_drivingDistance and pgr_KSP
>>>> Maybe, many users (like me) have QGIS 2.18
>>>> Some instructions about testing the phases would be needed.
>>>> About initial decisions of what can be included:
>>>> Now that we are starting a new major
>>>> one thing is I learned is don't include what does not work
>>>> In our case, besides pgRoutingLayer code correctness, we depend on the
>>>> correctness of pgRouting :
>>>> About withPoints & all proposed functions
>>>> https://docs.pgrouting.org/2.6/en/proposed.html#stable
>>>> There is a warning. and some detected issues:
>>>> https://github.com/pgRouting/pgrouting/issues?q=is%3Aopen+is%3Aissue+label%3AwithPoints
>>>> About experimental functions:
>>>> https://docs.pgrouting.org/2.6/en/proposed.html#experimental-functions
>>>> About pgr_dijkstraCost in QGiS I use it (to generate the image) here:
>>>> https://workshop.pgrouting.org/2.5.0/en/chapters/shortest_path.html#exercise-5-many-pedestrians-going-to-different-destinations-returning-aggregate-costs
>>>> compare VS
>>>> https://workshop.pgrouting.org/2.5.0/en/chapters/shortest_path.html#exercise-4-many-pedestrians-going-to-different-destinations
>>>> It gives a different perspective of the results of pgr_dijkstra
>>>> As reference:
>>>> This is the latest pgRouting documentation
>>>> https://docs.pgrouting.org/2.6/en/index.htm
>>>> This is the pgRouting 3.0.0-dev documentation (to be released on
>>>> September 2019)
>>>> https://docs.pgrouting.org/dev/en/index.html
>>>> Lots of things to plan
>>>> Regards
>>>> Vicky
>>>> On Tue, Oct 2, 2018 at 7:32 PM Cayetano Benavent <
>>>>> Hi all,
>>>>> I have finally cleaned code and fixed last bugs in python3 branch from
>>>>> pgRoutingLayer with all the work done by student Aasheesh Tiwari
>>>>> (@AasheeshT) this summer in GSOC.
>>>>> I would like to merge python3 branch with master and upload a QGIS3
>>>>> version. I've tested this code and it is working well in QGIS3 although
>>>>> there is still a lot of work to do :)
>>>>> It is important to note that I've removed several functions (what I
>>>>> really did is comment access from GUI):
>>>>> - WithPoints family: these functions don't work well because they were
>>>>> a very last addition in GSOC. We will add this code when Aasheesh (or
>>>>> somebody) fixes them.
>>>>> - TSP euclidean: This function is not working properly (before GSOC
>>>>> this function does not work well). I think is more useful to add pgr_TSP in
>>>>> the future that fix euclidean version.
>>>>> - DijkstraCost: This function is not working properly and I don't
>>>>> undestand very well the purpose of this function in QGIS.
>>>>> Deprecated functions were also removed (kdijkstra_path
>>>>> and kdijkstra_cost) but in this case we removed all the code.
>>>>> Thanks,
>>>>> +34 954 095 876
>>>>> www.geographica.gs
>>>>> _______________________________________________
>>>>> pgrouting-dev mailing list
>>>>> pgrouting-dev at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>>>> Georepublic UG (haftungsbeschränkt)
>>>> Salzmannstraße 44,
>>>> 81739 München, Germany
>>>> Vicky Vergara
>>>> Operations Research
>>>> eMail: vicky at georepublic.de
>>>> Web: https://georepublic.info
>>>> Tel: +49 (089) 4161 7698-1
>>>> Fax: +49 (089) 4161 7698-9
>>>> Commercial register: Amtsgericht München, HRB 181428
>>>> CEO: Daniel Kastl
> Salzmannstraße 44,
> Vicky Vergara
> Operations Research
> CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20181011/16802853/attachment-0001.html>
More information about the pgrouting-dev
