[pgrouting-dev] pgRoutingLayer QGIS3 version
Worth Lutz
wal3 at mindspring.com
Thu Oct 11 10:27:04 PDT 2018
This may be helpful for the project. https://editorconfig.org/
Take a look and see if it will help keep coding in the project consistent.
I have no connection with editorconfig except that I use it.
*Worth Lutz*
On 10/11/2018 1:06 PM, Cayetano Benavent wrote:
> Hi Vicky,
> Python has several linters. I propose to use for pgRoutingLayer
> project this tool: PyLint (http://pylint.pycqa.org). PyLynt is
> mantained by Python Code Quality Authority (http://meta.pycqa.org). I
> need to prepare and include a configuration file (.pylintrc) in
> repository.
> To test this new release I will write a wiki explaining how can you do it.
> Thanks,
> *Cayetano Benavent
> *Head of Data
> +34 954 095 876 <tel:%2B34%20954%20095%20876>
> www.geographica.gs <http://www.geographica.gs/>
> El mié., 10 oct. 2018 a las 15:44, Vicky Vergara
> (<vicky at georepublic.de <mailto:vicky at georepublic.de>>) escribió:
> Hi Cayetano
> Does python has some sort of code linter?
> Would be nice to lint the code and set some standards,
> like use spaces instead of tabs, how many spaces, etc.
> I am not a python expert but for C++ I use googles linter:
> https://github.com/cpplint/cpplint
> BTW, what do I have to do to test the the release?
> Regards Vicky
> On Wed, Oct 10, 2018 at 3:10 AM Cayetano Benavent
> <cayetano.benavent at geographica.gs
> <mailto:cayetano.benavent at geographica.gs>> wrote:
> Hi all,
> I have merged PR#82
> <https://github.com/pgRouting/pgRoutingLayer/pull/82> and
> published the new pre-release "v3.0.0-alpha1":
> https://github.com/pgRouting/pgRoutingLayer/releases/tag/v3.0.0-alpha1
> I know we need to do more work but I have little time and I
> think priority is to have a QGIS3 version to share with
> community.
> More things: I would like to update the Readme file because it
> is totally outdated.
> Thanks!
> *Cayetano Benavent
> *Head of Data
> El jue., 4 oct. 2018 a las 12:44, Cayetano Benavent
> (<cayetano.benavent at geographica.gs
> <mailto:cayetano.benavent at geographica.gs>>) escribió:
> Hi all,
> Works I have done:
> - I've updated develop branch because it was very outdated
> (now is paired with master).
> - I've changed base branch (now is develop) for PR to
> merge all the works for QGIS3 version:
> - I've created "gsoc2018" tag with all the works derived
> from GSOC 2018 by Aasheesh Tiwari past summer:
> https://github.com/pgRouting/pgRoutingLayer/tree/gsoc2018
> In several days we remove python3 branch, we will merge
> PR#82
> we will create v3.0.0-alpha1 version (without
> pgr_DijkstraCost).
> Regarding to DijkstraCost function, I will try to review
> it again to include in v3.0.0-alpha2 version (now I
> understand his utility in QGIS :) ).
> It is important understand several things to do a better
> planning of pgRoutingLayer future:
> - QGIS2 is developed entirely with Python 2.
> - QGIS3 is developed entirely with Python 3 and PyQGIS API
> is very different to QGIS2.
> - Python 2 EOL (end of life) is very near (Python 2 will
> be retired in 1 year) (https://pythonclock.org/ and
> https://www.python.org/dev/peps/pep-0373/).
> Taking in consideration this information we should not
> spend time to code in Python 2 so we only can develop in
> one direction: QGIS3.
> Last pgRoutingLayer version for QGIS2 should be 2.2
> (actually this is the last version uploaded to QGIS plugin
> hub).
> QGIS3 is very (very) superior to QGIS2 (most of his core
> has been rewrited) so if you can migrate version (2 to 3)
> you should do. I can help you if you do not know how to
> migrate version (it is very easy in all operative systems).
> We are very near to have a QGIS3 version!
> Regards,
> *Cayetano Benavent
> *Head of Data
> El mié., 3 oct. 2018 a las 17:01, Vicky Vergara
> escribió:
> Hi Cayetano
> Please Merge first the branch to "develop" branch.
> And clean the repository
> send a mail to this list about the branches that will
> be deleted,
> wait 3 or 4 days for people to double check that no
> "important" work will be deleted.
> Make sure that the tag that contains the GSoC students
> work was created.
> (and the tag has as last commit, the last commit of
> the student during the program)
> I really don't remember if I taged his work, we never
> continue work on a students branch,
> that branch has to remain intact when the GoC program
> is over that contains the students work and his work only.
> By cleaning the repo:
> When people clone or update their fork, they would
> only get master and develop branch.
> master has pgRoutingLayer v2.2.0 and branch develop
> has v3.0.0-dev
> Because the version is a "major" change we have to go
> thru the following phases:
> v3.0.0-alpha (v3.0.0-alpha1 if needed see bellow)
> v3.0.0-beta
> v3.0.0-rc
> etc.
> Use that versioning numberingto create the following
> branches & tags
> v3.0.0-alpha1 Includes all the functions that are coded
> v3.0.0-alpha2 Remove function(s) that is(are)
> well-known to have issues (issues must be documented
> on the issue list)
> or
> v3.0.0-alpha Include only the functions that
> supposedly work well
> or
> v3.0.0-alpha1 Includes only pgr_dijkstra
> v3.0.0-alpha2 Includes also pgr_dijkstraCost
> etc ...
> I like third option best because also work on
> documentation has to be done.
> So make users documentation of pgr_dijkstra and make
> the alpha with only that function
> So gradually documentation and functionality come in
> an alpha
> I know version pgRoutingLayer v3.0.0 will use python3
> what I dont know, is which versions of QGIS it will work.
> The version v2.0 didn't handle the functions with the
> "pgr_" is that going to remain the same?
> Which versions of pgRouting will it work with?
> I guess you removed all the deprecated functions, so
> for example, and kept for example
> for 2.1: pgr_dijkstra, pgr_drivingDistance and pgr_KSP
> Maybe, many users (like me) have QGIS 2.18
> Some instructions about testing the phases would be
> needed.
> About initial decisions of what can be included:
> Now that we are starting a new major
> one thing is I learned is don't include what does not work
> In our case, besides pgRoutingLayer code correctness,
> we depend on the correctness of pgRouting :
> About withPoints & all proposed functions
> https://docs.pgrouting.org/2.6/en/proposed.html#stable
> There is a warning. and some detected issues:
> https://github.com/pgRouting/pgrouting/issues?q=is%3Aopen+is%3Aissue+label%3AwithPoints
> About experimental functions:
> https://docs.pgrouting.org/2.6/en/proposed.html#experimental-functions
> About pgr_dijkstraCost in QGiS I use it (to generate
> the image) here:
> https://workshop.pgrouting.org/2.5.0/en/chapters/shortest_path.html#exercise-5-many-pedestrians-going-to-different-destinations-returning-aggregate-costs
> compare VS
> https://workshop.pgrouting.org/2.5.0/en/chapters/shortest_path.html#exercise-4-many-pedestrians-going-to-different-destinations
> It gives a different perspective of the results of
> pgr_dijkstra
> As reference:
> This is the latest pgRouting documentation
> https://docs.pgrouting.org/2.6/en/index.htm
> This is the pgRouting 3.0.0-dev documentation (to be
> released on September 2019)
> https://docs.pgrouting.org/dev/en/index.html
> Lots of things to plan
> Regards
> Vicky
> On Tue, Oct 2, 2018 at 7:32 PM Cayetano Benavent
> Hi all,
> I have finally cleaned code and fixed last bugs in
> python3 branch from pgRoutingLayer with all the
> work done by student Aasheesh Tiwari (@AasheeshT)
> this summer in GSOC.
> I would like to merge python3 branch with master
> and upload a QGIS3 version. I've tested this code
> and it is working well in QGIS3 although there is
> still a lot of work to do :)
> It is important to note that I've removed several
> functions (what I really did is comment access
> from GUI):
> - WithPoints family: these functions don't work
> well because they were a very last addition in
> GSOC. We will add this code when Aasheesh (or
> somebody) fixes them.
> - TSP euclidean: This function is not working
> properly (before GSOC this function does not work
> well). I think is more useful to add pgr_TSP in
> the future that fix euclidean version.
> - DijkstraCost: This function is not working
> properly and I don't undestand very well the
> purpose of this function in QGIS.
> Deprecated functions were also removed
> (kdijkstra_path and kdijkstra_cost) but in this
> case we removed all the code.
> Thanks,
> *Cayetano Benavent
> *Head of Data
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> <mailto:pgrouting-dev at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> Georepublic UG (haftungsbeschränkt)
> Salzmannstraße 44,
> 81739 München, Germany
> Vicky Vergara
> Operations Research
> eMail: vicky at georepublic.de <http://georepublic.de>
> Web:https://georepublic.info
> Tel: +49 (089) 4161 7698-1
> Fax: +49 (089) 4161 7698-9
> Commercial register: Amtsgericht München, HRB 181428
> CEO: Daniel Kastl
> Salzmannstraße 44,
> Vicky Vergara
> Operations Research
> CEO: Daniel Kastl
> pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20181011/80e1e716/attachment-0001.html>
More information about the pgrouting-dev
