[pgrouting-dev] pgRoutingLayer QGIS3 version
Vicky Vergara
vicky at georepublic.de
Thu Oct 11 12:31:52 PDT 2018
Yes,
good idea, many editors use that .editorconfig file
On Thu, Oct 11, 2018 at 12:51 PM Worth Lutz <wal3 at mindspring.com> wrote:
> This may be helpful for the project. https://editorconfig.org/
> Take a look and see if it will help keep coding in the project consistent.
> I have no connection with editorconfig except that I use it.
> *Worth Lutz*
> On 10/11/2018 1:06 PM, Cayetano Benavent wrote:
> Hi Vicky,
> Python has several linters. I propose to use for pgRoutingLayer project
> this tool: PyLint (http://pylint.pycqa.org). PyLynt is mantained
> by Python Code Quality Authority (http://meta.pycqa.org). I need to
> prepare and include a configuration file (.pylintrc) in repository.
> To test this new release I will write a wiki explaining how can you do it.
> Thanks,
> *Cayetano Benavent *Head of Data
> +34 954 095 876 <%2B34%20954%20095%20876>
> www.geographica.gs
> El mié., 10 oct. 2018 a las 15:44, Vicky Vergara (<vicky at georepublic.de>)
> escribió:
>> Hi Cayetano
>> Does python has some sort of code linter?
>> Would be nice to lint the code and set some standards,
>> like use spaces instead of tabs, how many spaces, etc.
>> I am not a python expert but for C++ I use googles linter:
>> https://github.com/cpplint/cpplint
>> BTW, what do I have to do to test the the release?
>> Regards Vicky
>> On Wed, Oct 10, 2018 at 3:10 AM Cayetano Benavent <
>> cayetano.benavent at geographica.gs> wrote:
>>> Hi all,
>>> I have merged PR#82
>>> <https://github.com/pgRouting/pgRoutingLayer/pull/82> and published the
>>> new pre-release "v3.0.0-alpha1":
>>> https://github.com/pgRouting/pgRoutingLayer/releases/tag/v3.0.0-alpha1
>>> I know we need to do more work but I have little time and I think
>>> priority is to have a QGIS3 version to share with community.
>>> More things: I would like to update the Readme file because it is
>>> totally outdated.
>>> Thanks!
>>> +34 954 095 876
>>> www.geographica.gs
>>> El jue., 4 oct. 2018 a las 12:44, Cayetano Benavent (<
>>> cayetano.benavent at geographica.gs>) escribió:
>>>> Hi all,
>>>> Works I have done:
>>>> - I've updated develop branch because it was very outdated (now is
>>>> paired with master).
>>>> - I've changed base branch (now is develop) for PR to merge all the
>>>> works for QGIS3 version:
>>>> - I've created "gsoc2018" tag with all the works derived from GSOC 2018
>>>> by Aasheesh Tiwari past summer:
>>>> https://github.com/pgRouting/pgRoutingLayer/tree/gsoc2018
>>>> In several days we remove python3 branch, we will merge PR#82
>>>> <https://github.com/pgRouting/pgRoutingLayer/pull/82> and we will
>>>> create v3.0.0-alpha1 version (without pgr_DijkstraCost).
>>>> Regarding to DijkstraCost function, I will try to review it again to
>>>> include in v3.0.0-alpha2 version (now I understand his utility in QGIS :) ).
>>>> It is important understand several things to do a better planning of
>>>> pgRoutingLayer future:
>>>> - QGIS2 is developed entirely with Python 2.
>>>> - QGIS3 is developed entirely with Python 3 and PyQGIS API is very
>>>> different to QGIS2.
>>>> - Python 2 EOL (end of life) is very near (Python 2 will be retired in
>>>> 1 year) (https://pythonclock.org/ and
>>>> https://www.python.org/dev/peps/pep-0373/).
>>>> Taking in consideration this information we should not spend time to
>>>> code in Python 2 so we only can develop in one direction: QGIS3.
>>>> Last pgRoutingLayer version for QGIS2 should be 2.2 (actually this is
>>>> the last version uploaded to QGIS plugin hub).
>>>> QGIS3 is very (very) superior to QGIS2 (most of his core has been
>>>> rewrited) so if you can migrate version (2 to 3) you should do. I can help
>>>> you if you do not know how to migrate version (it is very easy in all
>>>> operative systems).
>>>> We are very near to have a QGIS3 version!
>>>> Regards,
>>>> +34 954 095 876
>>>> www.geographica.gs
>>>> El mié., 3 oct. 2018 a las 17:01, Vicky Vergara (<vicky at georepublic.de>)
>>>> escribió:
>>>>> Hi Cayetano
>>>>> Please Merge first the branch to "develop" branch.
>>>>> And clean the repository
>>>>> send a mail to this list about the branches that will be deleted,
>>>>> wait 3 or 4 days for people to double check that no "important" work
>>>>> will be deleted.
>>>>> Make sure that the tag that contains the GSoC students work was
>>>>> created.
>>>>> (and the tag has as last commit, the last commit of the student during
>>>>> the program)
>>>>> I really don't remember if I taged his work, we never continue work on
>>>>> a students branch,
>>>>> that branch has to remain intact when the GoC program is over that
>>>>> contains the students work and his work only.
>>>>> By cleaning the repo:
>>>>> When people clone or update their fork, they would only get master and
>>>>> develop branch.
>>>>> master has pgRoutingLayer v2.2.0 and branch develop has v3.0.0-dev
>>>>> Because the version is a "major" change we have to go thru the
>>>>> following phases:
>>>>> v3.0.0-alpha (v3.0.0-alpha1 if needed see bellow)
>>>>> v3.0.0-beta
>>>>> v3.0.0-rc
>>>>> etc.
>>>>> Use that versioning numbering to create the following branches & tags
>>>>> v3.0.0-alpha1 Includes all the functions that are coded
>>>>> v3.0.0-alpha2 Remove function(s) that is(are) well-known to have
>>>>> issues (issues must be documented on the issue list)
>>>>> or
>>>>> v3.0.0-alpha Include only the functions that supposedly work well
>>>>> or
>>>>> v3.0.0-alpha1 Includes only pgr_dijkstra
>>>>> v3.0.0-alpha2 Includes also pgr_dijkstraCost
>>>>> etc ...
>>>>> I like third option best because also work on documentation has to be
>>>>> done.
>>>>> So make users documentation of pgr_dijkstra and make the alpha with
>>>>> only that function
>>>>> So gradually documentation and functionality come in an alpha
>>>>> I know version pgRoutingLayer v3.0.0 will use python3 what I dont
>>>>> know, is which versions of QGIS it will work.
>>>>> The version v2.0 didn't handle the functions with the "pgr_" is that
>>>>> going to remain the same?
>>>>> Which versions of pgRouting will it work with?
>>>>> I guess you removed all the deprecated functions, so for example, and
>>>>> kept for example
>>>>> for 2.1: pgr_dijkstra, pgr_drivingDistance and pgr_KSP
>>>>> Maybe, many users (like me) have QGIS 2.18
>>>>> Some instructions about testing the phases would be needed.
>>>>> About initial decisions of what can be included:
>>>>> Now that we are starting a new major
>>>>> one thing is I learned is don't include what does not work
>>>>> In our case, besides pgRoutingLayer code correctness, we depend on the
>>>>> correctness of pgRouting :
>>>>> About withPoints & all proposed functions
>>>>> https://docs.pgrouting.org/2.6/en/proposed.html#stable
>>>>> There is a warning. and some detected issues:
>>>>> https://github.com/pgRouting/pgrouting/issues?q=is%3Aopen+is%3Aissue+label%3AwithPoints
>>>>> About experimental functions:
>>>>> https://docs.pgrouting.org/2.6/en/proposed.html#experimental-functions
>>>>> About pgr_dijkstraCost in QGiS I use it (to generate the image) here:
>>>>> https://workshop.pgrouting.org/2.5.0/en/chapters/shortest_path.html#exercise-5-many-pedestrians-going-to-different-destinations-returning-aggregate-costs
>>>>> compare VS
>>>>> https://workshop.pgrouting.org/2.5.0/en/chapters/shortest_path.html#exercise-4-many-pedestrians-going-to-different-destinations
>>>>> It gives a different perspective of the results of pgr_dijkstra
>>>>> As reference:
>>>>> This is the latest pgRouting documentation
>>>>> https://docs.pgrouting.org/2.6/en/index.htm
>>>>> This is the pgRouting 3.0.0-dev documentation (to be released on
>>>>> September 2019)
>>>>> https://docs.pgrouting.org/dev/en/index.html
>>>>> Lots of things to plan
>>>>> Regards
>>>>> Vicky
>>>>> On Tue, Oct 2, 2018 at 7:32 PM Cayetano Benavent <
>>>>>> Hi all,
>>>>>> I have finally cleaned code and fixed last bugs in python3 branch
>>>>>> from pgRoutingLayer with all the work done by student Aasheesh Tiwari
>>>>>> (@AasheeshT) this summer in GSOC.
>>>>>> I would like to merge python3 branch with master and upload a QGIS3
>>>>>> version. I've tested this code and it is working well in QGIS3 although
>>>>>> there is still a lot of work to do :)
>>>>>> It is important to note that I've removed several functions (what I
>>>>>> really did is comment access from GUI):
>>>>>> - WithPoints family: these functions don't work well because they
>>>>>> were a very last addition in GSOC. We will add this code when Aasheesh (or
>>>>>> somebody) fixes them.
>>>>>> - TSP euclidean: This function is not working properly (before GSOC
>>>>>> this function does not work well). I think is more useful to add pgr_TSP in
>>>>>> the future that fix euclidean version.
>>>>>> - DijkstraCost: This function is not working properly and I don't
>>>>>> undestand very well the purpose of this function in QGIS.
>>>>>> Deprecated functions were also removed (kdijkstra_path
>>>>>> and kdijkstra_cost) but in this case we removed all the code.
>>>>>> Thanks,
>>>>>> +34 954 095 876
>>>>>> www.geographica.gs
>>>>>> _______________________________________________
>>>>>> pgrouting-dev mailing list
>>>>>> pgrouting-dev at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>>>>> Georepublic UG (haftungsbeschränkt)
>>>>> Salzmannstraße 44,
>>>>> 81739 München, Germany
>>>>> Vicky Vergara
>>>>> Operations Research
>>>>> eMail: vicky at georepublic.de
>>>>> Web: https://georepublic.info
>>>>> Tel: +49 (089) 4161 7698-1
>>>>> Fax: +49 (089) 4161 7698-9
>>>>> Commercial register: Amtsgericht München, HRB 181428
>>>>> CEO: Daniel Kastl
>> Salzmannstraße 44,
>> Vicky Vergara
>> Operations Research
>> CEO: Daniel Kastl
> pgrouting-dev mailing listpgrouting-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20181011/663414aa/attachment-0001.html>
More information about the pgrouting-dev
