[pgrouting-dev] [pgrouting-users] RFC3 Positional and named parameters on pgRouting functions
Vicky Vergara vicky at georepublic.de
Thu Oct 25 10:10:12 PDT 2018
Hi Daniel, there are INOUT parameters in postgres
But then using them will give the columns a strange ordering
like having the `seq` column in the second or third column.
On Wed, Oct 24, 2018 at 8:55 PM Daniel Kastl <daniel at georepublic.de> wrote:
> Hi Vicky,
> I agree with your proposal.
> There is maybe one point, which we would loose, when we remove the names
> on compulsory parameter: code readability.
> Take your example:
> https://github.com/pgRouting/admin/wiki/RFC3#developers-steps-to-take
> Now it's not so easy anymore to understand the first three input
> parameters, so I would suggest to somehow encourage developers (or make it
> a required formal rule) to append the parameter name in each line as a
> comment.
> CREATE OR REPLACE FUNCTION pgr_aStarCost(
>     ---------------- remove the names on compulsory parameters
>     TEXT,    # edges_sql (required)
>     BIGINT,  # start_vid (required)
>     BIGINT,  # end_vid (required)
>     directed BOOLEAN DEFAULT true,
> I understand, that PostgreSQL does not allow us to use the same attribute
> name twice for in IN and OUT parameters, if we want to use named
> parameters. But isn't this something that could be solved in future
> versions of PostgreSQL? Looks more like a bug than a feature, because why
> would someone want to use the parameter name of one, that is defined as
> "OUT"?
> Best regards,
> Daniel
> On Thu, Oct 25, 2018 at 3:44 AM Vicky Vergara <vicky at georepublic.de>
> wrote:
>> Dear Users and developers
>> We would like to hear your feedback about:
>> That is described here:
>> The aim is to enforce positional notation on compulsory parameters and
>> allow named notation on optional parameters
>> That enforcement would take place on version 3.0.0 scheduled to be
>> released on September 2019.
>> We will appreciate your feedback.
>> Regards
>> The pgRouting team
>> Georepublic UG (haftungsbeschränkt)
>> Salzmannstraße 44,
>> 81739 München, Germany
>> Vicky Vergara
>> Operations Research
>> eMail: vicky at georepublic.de
>> Web: https://georepublic.info
>> Tel: +49 (089) 4161 7698-1
>> Fax: +49 (089) 4161 7698-9
>> Commercial register: Amtsgericht München, HRB 181428
>> CEO: Daniel Kastl
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20181025/4a194065/attachment.html>
More information about the pgrouting-dev mailing list
