[pgrouting-dev] Postgres AssertFailedException Exception
Patil, Prashant Prashant.Patil at crowncastle.com
Thu Dec 19 04:19:57 PST 2019
Hi Team,
We are receiving following AssertFailedException exception while executing pgrouting query listed below. Anyone have idea about this exception? Is this known bug? Possible fix? Is this something hangs the whole process?
Server details -
Postgresql 9.3.25 ( we are in process of upgrading to 11)
Ubuntu 16.04.6 LTS
Pgrouting 2.6.0
2019-12-16 19:31:55 EST Passenger AppPreloader: /var/w...er.com/ViewEngine (forking...) [41329-3] postgres at odw ERROR:  AssertFailedException: p1.tot_cost() == p2.tot_cost() at /build/pgrouting-Prt6v2/pgrouting-2.6.0/include/yen/pgr_ksp.hpp:63
               *** Execution path***
               [bt]/usr/lib/postgresql/9.3/lib/libpgrouting-2.6.so(_Z13get_backtraceB5cxx11v+0x3c) [0x7ff5fd368b7c]
               [bt]/usr/lib/postgresql/9.3/lib/libpgrouting-2.6.so(_ZNK7Pgr_kspIN9pgrouting5graph14Pgr_base_graphIN5boost14adjacency_listINS3_4vecSES5_NS3_11undirectedSENS0_12Basic_vertexENS0_10Basic_edgeENS3_11no_propertyENS3_5listSEEES7_S8_EEE9compPathsclERK4PathSH_+0x2dd) [0x7ff5fd3d2bbd]
               [bt]/usr/lib/postgresql/9.3/lib/libpgrouting-2.6.so(_ZNSt8_Rb_treeI4PathS0_St9_IdentityIS0_EN7Pgr_kspIN9pgrouting5graph14Pgr_base_graphIN5boost14adjacency_listINS7_4vecSES9_NS7_11undirectedSENS4_12Basic_vertexENS4_10Basic_edgeENS7_11no_propertyENS7_5listSEEESB_SC_EEE9compPathsESaIS0_EE16_M_insert_uniqueIRKS0_EESt4pairISt17_Rb_tree_iteratorIS0_EbEOT_+0x4e) [0x7ff5fd3d2dae]
               [bt]/usr/lib/postgresql/9.3/lib/libpgrouting-2.6.so(_ZN7Pgr_kspIN9pgrouting5graph14Pgr_base_graphIN5boost14adjacency_listINS3_4vecSES5_NS3_11undirectedSENS0_12Basic_vertexENS0_10Basic_edgeENS3_11no_propertyENS3_5listSEEES7_S8_EEE11doNextCycleERSC_+0x641) [0x7ff5fd3e2251]
               [bt]/usr/lib/postgresql/9.3/lib/libpgrouting-2.6.so(_ZN7Pgr_kspIN9pgrouting5graph14Pgr_base_graphIN5boost14adjacency_listINS3_4vecSES5_NS3_11undirectedSENS0_12Basic_vertexENS0_10Basic_edgeENS3_11no_propertyENS3_5listSEEES7_S8_EEE3YenERSC_llib+0x2fb) [0x7ff5fd3e288b]
               [bt]/usr/lib/postgresql/9.3/lib/libpgrouting-2.6.so(do_pgr_ksp+0xbd4) [0x7ff5fd3e5f84]
               [bt]/usr/lib/postgresql/9.3/lib/libpgrouting-2.6.so(kshortest_path+0x40e) [0x7ff5fd3ced4e]
               [bt]postgres: postgres odw 10.76.0.185(44748) SELECT(ExecMakeTableFunctionResult+0x19c) [0x55625ab1dcbc]
               [bt]postgres: postgres odw 10.76.0.185(44748) SELECT(+0x1dc116) [0x55625ab31116]
               [bt]postgres: postgres odw 10.76.0.185(44748) SELECT(ExecScan+0x2c9) [0x55625ab1feb9]
               [bt]postgres: postgres odw 10.76.0.185(44748) SELECT(ExecProcNode+0x1a8) [0x55625ab187e8]
               [bt]postgres: postgres odw 10.76.0.185(44748) SELECT(standard_ExecutorRun+0x10e) [0x55625ab15c6e]
               [bt]/usr/lib/postgresql/9.3/lib/pg_stat_statements.so(+0x24a5) [0x7ffa2048a4a5]
               [bt]postgres: postgres odw 10.76.0.185(44748) SELECT(+0x2a8717) [0x55625abfd717]
               [bt]postgres: postgres odw 10.76.0.185(44748) SELECT(PortalRunFetch+0x180) [0x55625abff0a0]
               [bt]postgres: postgres odw 10.76.0.185(44748) SELECT(+0x1e423d) [0x55625ab3923d]
2019-12-16 19:31:55 EST Passenger AppPreloader: /var/w...er.com/ViewEngine (forking...) [41329-4] postgres at odw HINT:
2019-12-16 19:31:55 EST Passenger AppPreloader: /var/w...er.com/ViewEngine (forking...) [41329-5] postgres at odw CONTEXT:  PL/pgSQL function pgr_ksp(text,bigint,bigint,integer,boolean,boolean) line 4 at RETURN QUERY
               PL/pgSQL function nn_candidate_routes_from_and_to_latlon(geometry,geometry[]) line 75 at RETURN QUERY
2019-12-16 19:31:55 EST Passenger AppPreloader: /var/w...er.com/ViewEngine (forking...) [41329-6] postgres at odw STATEMENT:
                       select st_multi(st_union(geom)) as geom,return_target_seq,path_id,st_length(st_union(st_transform(geom,2163))) as distance
                        from nn_candidate_routes_from_and_to_latlon(st_setsrid(st_makepoint(-117.99466873924484,33.92814775576908),4326), ARRAY(
                       select geom from (
                       select geom, st_distance(st_setsrid(st_makepoint(-117.99466873924484,33.92814775576908),4326),geom)
                       from (
                          select
                        (st_dumppoints((st_transform(st_segmentize(st_transform(wkt_geometry,2163),75),4326)))).geom
                        from (select * from staging_dw_cables where upper(owner) ~ 'OWNED' and start_ne_dw_enclosure_id is not null and end_ne_dw_enclosure_id is not null and pop_cable_tf = true
                        and wkt_geometry && st_transform(st_buffer(st_transform(st_setsrid(st_makepoint(-117.99466873924484,33.92814775576908),4326),2163),50000),4326)
                        order by st_distance(st_setsrid(st_makepoint(-117.99466873924484,33.92814775576908),4326),wkt_geometry) limit 15) cables) sq order by 2 asc limit 15) sq
                        )) where geom is not null group by return_target_seq,path_id order by distance asc limit 25
Regards,
Prashant
This email may contain confidential or privileged material. Use or disclosure of it by anyone other than the recipient is unauthorized. If you are not an intended recipient, please delete this email.
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20191219/85021452/attachment.html>
More information about the pgrouting-dev mailing list
