[pgrouting-dev] Postgres AssertFailedException Exception
Daniel Kastl
daniel at georepublic.de
Thu Dec 19 05:09:55 PST 2019
Hi Prashant,
As you say your version of PostgreSQL is one that is not supported anymore
and also your pgRouting version has seen a few bugfix releases already.
It could be a data problem like here:
https://github.com/pgRouting/pgrouting/issues/1152
But it would be really best if you could first upgrade to newer versions
and try again.
Best regards,
Daniel
On Thu, Dec 19, 2019 at 9:20 PM Patil, Prashant <
Prashant.Patil at crowncastle.com> wrote:
> Hi Team,
> We are receiving following AssertFailedException exception while executing
> pgrouting query listed below. Anyone have idea about this exception? Is
> this known bug? Possible fix? Is this something hangs the whole process?
> Server details -
> Postgresql 9.3.25 ( we are in process of upgrading to 11)
> Ubuntu 16.04.6 LTS
> Pgrouting 2.6.0
> 2019-12-16 19:31:55 EST Passenger AppPreloader: /var/w...er.com/ViewEngine
> (forking...) [41329-3] postgres at odw ERROR: *AssertFailedException*:
> p1.tot_cost() == p2.tot_cost() at
> /build/pgrouting-Prt6v2/pgrouting-2.6.0/include/yen/pgr_ksp.hpp:63
> *** Execution path***
> [bt]/usr/lib/postgresql/9.3/lib/libpgrouting-2.6.so(_Z13get_backtraceB5cxx11v+0x3c)
> [0x7ff5fd368b7c]
> [bt]/usr/lib/postgresql/9.3/lib/libpgrouting-2.6.so(_ZNK7Pgr_kspIN9pgrouting5graph14Pgr_base_graphIN5boost14adjacency_listINS3_4vecSES5_NS3_11undirectedSENS0_12Basic_vertexENS0_10Basic_edgeENS3_11no_propertyENS3_5listSEEES7_S8_EEE9compPathsclERK4PathSH_+0x2dd)
> [0x7ff5fd3d2bbd]
> [bt]/usr/lib/postgresql/9.3/lib/libpgrouting-2.6.so(_ZNSt8_Rb_treeI4PathS0_St9_IdentityIS0_EN7Pgr_kspIN9pgrouting5graph14Pgr_base_graphIN5boost14adjacency_listINS7_4vecSES9_NS7_11undirectedSENS4_12Basic_vertexENS4_10Basic_edgeENS7_11no_propertyENS7_5listSEEESB_SC_EEE9compPathsESaIS0_EE16_M_insert_uniqueIRKS0_EESt4pairISt17_Rb_tree_iteratorIS0_EbEOT_+0x4e)
> [0x7ff5fd3d2dae]
> [bt]/usr/lib/postgresql/9.3/lib/libpgrouting-2.6.so(_ZN7Pgr_kspIN9pgrouting5graph14Pgr_base_graphIN5boost14adjacency_listINS3_4vecSES5_NS3_11undirectedSENS0_12Basic_vertexENS0_10Basic_edgeENS3_11no_propertyENS3_5listSEEES7_S8_EEE11doNextCycleERSC_+0x641)
> [0x7ff5fd3e2251]
> [bt]/usr/lib/postgresql/9.3/lib/libpgrouting-2.6.so(_ZN7Pgr_kspIN9pgrouting5graph14Pgr_base_graphIN5boost14adjacency_listINS3_4vecSES5_NS3_11undirectedSENS0_12Basic_vertexENS0_10Basic_edgeENS3_11no_propertyENS3_5listSEEES7_S8_EEE3YenERSC_llib+0x2fb)
> [0x7ff5fd3e288b]
> [bt]/usr/lib/postgresql/9.3/lib/libpgrouting-2.6.so(do_pgr_ksp+0xbd4)
> [0x7ff5fd3e5f84]
> [bt]/usr/lib/postgresql/9.3/lib/libpgrouting-2.6.so(kshortest_path+0x40e)
> [0x7ff5fd3ced4e]
> [bt]postgres: postgres odw 10.76.0.185(44748)
> SELECT(ExecMakeTableFunctionResult+0x19c) [0x55625ab1dcbc]
> SELECT(+0x1dc116) [0x55625ab31116]
> SELECT(ExecScan+0x2c9) [0x55625ab1feb9]
> SELECT(ExecProcNode+0x1a8) [0x55625ab187e8]
> SELECT(standard_ExecutorRun+0x10e) [0x55625ab15c6e]
> [bt]/usr/lib/postgresql/9.3/lib/pg_stat_statements.so(+0x24a5)
> [0x7ffa2048a4a5]
> SELECT(+0x2a8717) [0x55625abfd717]
> SELECT(PortalRunFetch+0x180) [0x55625abff0a0]
> SELECT(+0x1e423d) [0x55625ab3923d]
> (forking...) [41329-4] postgres at odw HINT:
> (forking...) [41329-5] postgres at odw CONTEXT: PL/pgSQL function
> pgr_ksp(text,bigint,bigint,integer,boolean,boolean) line 4 at RETURN QUERY
> PL/pgSQL function
> nn_candidate_routes_from_and_to_latlon(geometry,geometry[]) line 75 at
> RETURN QUERY
> (forking...) [41329-6] postgres at odw STATEMENT:
> select st_multi(st_union(geom)) as
> geom,return_target_seq,path_id,st_length(st_union(st_transform(geom,2163)))
> as distance
> from
> nn_candidate_routes_from_and_to_latlon(st_setsrid(st_makepoint(-117.99466873924484,33.92814775576908),4326),
> ARRAY(
> select geom from (
> select geom,
> st_distance(st_setsrid(st_makepoint(-117.99466873924484,33.92814775576908),4326),geom)
> from (
> select
> (st_dumppoints((st_transform(st_segmentize(st_transform(wkt_geometry,2163),75),4326)))).geom
> from (select * from staging_dw_cables where
> upper(owner) ~ 'OWNED' and start_ne_dw_enclosure_id is not null and
> end_ne_dw_enclosure_id is not null and pop_cable_tf = true
> and wkt_geometry &&
> st_transform(st_buffer(st_transform(st_setsrid(st_makepoint(-117.99466873924484,33.92814775576908),4326),2163),50000),4326)
> order by
> st_distance(st_setsrid(st_makepoint(-117.99466873924484,33.92814775576908),4326),wkt_geometry)
> limit 15) cables) sq order by 2 asc limit 15) sq
> )) where geom is not null group by
> return_target_seq,path_id order by distance asc limit 25
> Regards,
> Prashant
> This email may contain confidential or privileged material. Use or
> disclosure of it by anyone other than the recipient is unauthorized. If you
> are not an intended recipient, please delete this email.
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: https://georepublic.info
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20191219/ae599054/attachment-0001.html>
More information about the pgrouting-dev
