[pgrouting-dev] Proposal for Cleanup of pgRouting/Workshop Github Repository
    Rajat Shinde
    rajatshinde2303 at gmail.com
    Mon Dec 21 11:21:18 PST 2020
Hello all,
The pgRouting community proposes cleanup of pgRouting/Workshop Github
repository [1].
We should only have the following branches:
main [2]
develop
gh-pages
Some of the problems are:
   - Some of the branches are 10 years old such as "FOSS4G2011" branch [3]
   which is already published at [4].
   - The FOSS4G Hokkaido workshop is not yet published on the pgRouting
   Workshop website [5] and the development of the "develop/hokkaido" branch
   is stalled since 2015 [6].
   - Many branches start with "develop/" (the "/" normally indicates it
   belongs to a repository named develop).
This last example is causing some development issues: We are working on
having a configured workshop and had to name the working branch as
"general-develop" branch due to the lack of "develop" branch and many
existing "develop/foo" branches, creating confusion about the correct
branch for developing.
Proposal to cleanup of the Workshop repository:
Remember that Github handles tags with semantic versioning, the latest
version corresponds to the last pushed tag and any new tags for the stalled
branches will not be versioned tags.
The cleanup would comprise of following steps:
   1. Make sure that tags exist for the international FOSS4G workshops
      1. Find the versioned number corresponding to the international branch
      2. If it does not exist, then create a tag with the name:
      FOSS4G<YEAR><PLACE>
      3. Delete the branch
   2. Make sure that tags exist for the local FOSS4G workshops
      1. These are not versioned
      2. Find a corresponding tag for the local branch
      3. If it does not exist, then create a tag with the name:
      <PLACE><LAST YEAR OF MODIFICATION>
      4. Delete the branch
   3. Rename "general-develop" to "develop"
      1. Create branch "develop" based on "general-develop"
      2. Delete branch "general-develop"
   4. Rename "master" to "main"
      1. Create branch "main" based on "master"
      2. Pending the delete of "master" until things work properly on
      Github for branch "main"
If this proposal is accepted, I will open an administrative issue on the
pgRouting/Workshop Github repository [7], to keep track of all the steps
mentioned. The related tags will be placed as Github issues and before
removing any branch, a comment will be posted to get thumbs up. A comment
will follow post removal of the branch as well.
Thanks!
Kind regards,
pgRouting Team
[1] https://github.com/pgRouting/workshop/branches/all
[2] https://github.com/github/renaming
[3] https://github.com/pgRouting/workshop/tree/foss4g2011
[4] https://workshop.pgrouting.org/0.6.1/en/index.html
[5] https://workshop.pgrouting.org/
[6] https://github.com/pgRouting/workshop/tree/develop/hokkaido
[7] https://github.com/pgRouting/workshop
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20201222/0d8484f2/attachment.html>
More information about the pgrouting-dev
