[pgrouting-dev] Proposal for Cleanup of pgRouting/Workshop Github Repository
Daniel Kastl
daniel at georepublic.de
Mon Dec 21 17:10:46 PST 2020
Thanks, this is a good proposal!
I agree that cleanup is good and that we should have less branches and more
clear conventions.
Sometimes branches may be different to the main workshop, so I'm not sure
if a tag would solve the problem.
But whenever a tag (release) solves it, then it's perfectly fine.
I'm actually not sure if it really makes sense to keep a long list of old
workshops.
Who will ever do the old one? Should we really encourage people to look at
old ones?
Maybe it would be even better to just have a single workshop.
Regarding branch names, "main" is good and an alternative to "develop"
could be "next".
It is shorter and indicates that it will be the next release. If we already
rename things, we could do this as well.
We could also wait with renaming "master" as Github seems to prepare
something that will prevent to break stuff:
https://github.com/github/renaming
Best regards,
Daniel
On Tue, 22 Dec 2020 at 07:20, Vicky Vergara <vicky at georepublic.de> wrote:
> Hello Rajat,
> I think cleaning up that repo is going to be good.
> I see your detailed proposal, and I think it is very clear on how to
> proceed so we do not lose any information
> Thanks for the proposal, from my part it is a thumbs up.
> Let's wait until next monday to see if someone else has a suggestion on
> how to proceed with the cleanup.
> Thanks for your efforts
> On Mon, Dec 21, 2020 at 1:21 PM Rajat Shinde <rajatshinde2303 at gmail.com>
> wrote:
>> Hello all,
>> The pgRouting community proposes cleanup of pgRouting/Workshop Github
>> repository [1].
>> We should only have the following branches:
>> main [2]
>> develop
>> gh-pages
>> Some of the problems are:
>> - Some of the branches are 10 years old such as "FOSS4G2011" branch
>> [3] which is already published at [4].
>> - The FOSS4G Hokkaido workshop is not yet published on the pgRouting
>> Workshop website [5] and the development of the "develop/hokkaido" branch
>> is stalled since 2015 [6].
>> - Many branches start with "develop/" (the "/" normally indicates it
>> belongs to a repository named develop).
>> This last example is causing some development issues: We are working on
>> having a configured workshop and had to name the working branch as
>> "general-develop" branch due to the lack of "develop" branch and many
>> existing "develop/foo" branches, creating confusion about the correct
>> branch for developing.
>> Proposal to cleanup of the Workshop repository:
>> Remember that Github handles tags with semantic versioning, the latest
>> version corresponds to the last pushed tag and any new tags for the stalled
>> branches will not be versioned tags.
>> The cleanup would comprise of following steps:
>> 1. Make sure that tags exist for the international FOSS4G workshops
>> 1. Find the versioned number corresponding to the international
>> branch
>> 2. If it does not exist, then create a tag with the name:
>> FOSS4G<YEAR><PLACE>
>> 3. Delete the branch
>> 2. Make sure that tags exist for the local FOSS4G workshops
>> 1. These are not versioned
>> 2. Find a corresponding tag for the local branch
>> 3. If it does not exist, then create a tag with the name:
>> <PLACE><LAST YEAR OF MODIFICATION>
>> 4. Delete the branch
>> 3. Rename "general-develop" to "develop"
>> 1. Create branch "develop" based on "general-develop"
>> 2. Delete branch "general-develop"
>> 4. Rename "master" to "main"
>> 1. Create branch "main" based on "master"
>> 2. Pending the delete of "master" until things work properly on
>> Github for branch "main"
>> If this proposal is accepted, I will open an administrative issue on the
>> pgRouting/Workshop Github repository [7], to keep track of all the steps
>> mentioned. The related tags will be placed as Github issues and before
>> removing any branch, a comment will be posted to get thumbs up. A comment
>> will follow post removal of the branch as well.
>> Thanks!
>> Kind regards,
>> pgRouting Team
>> [1] https://github.com/pgRouting/workshop/branches/all
>> [2] https://github.com/github/renaming
>> [3] https://github.com/pgRouting/workshop/tree/foss4g2011
>> [4] https://workshop.pgrouting.org/0.6.1/en/index.html
>> [5] https://workshop.pgrouting.org/
>> [6] https://github.com/pgRouting/workshop/tree/develop/hokkaido
>> [7] https://github.com/pgRouting/workshop
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> Georepublic UG (haftungsbeschränkt)
> Salzmannstraße 44,
> 81739 München, Germany
> Vicky Vergara
> Operations Research
> eMail: vicky at georepublic.de
> Web: https://georepublic.info
> Tel: +49 (089) 4161 7698-1
> Fax: +49 (089) 4161 7698-9
> Commercial register: Amtsgericht München, HRB 181428
> CEO: Daniel Kastl
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20201222/e874d7e7/attachment-0001.html>
More information about the pgrouting-dev
