[pgrouting-dev] GSoC 2020 - Lengauer Tarjan dominator Tree and Two graphs common Spanning Trees for pgRouting - Weekly Report [Week 6]
Prakash Tiwari 85prakash2017 at gmail.com
Sun Jul 12 12:29:56 PDT 2020
Hello Everyone,
This is my weekly report for week [6] (Jul 7th -Jul 12th).The report
can also be found in project wiki [1].
What did I get done this week?
   - Created the pull request in which my weekly progress can be
   reviewed.[2]
   - Completed the coding of SQL functions that are pgr_mrt.sql and
   _pgr_mrt.sql.
   - Fix the signature of Lengauer Tarjan dominator Tree. (Rename from
   LTDTree to lengauer_tarjan_dominator_tree).
   - - Changed the name of the function in LTDTree.c file to solve the
   errors.
   - - Changed the name of functions in pgTap tests to proper testing.
   - - Changed the signature of the function in pgrouting--3.0.0.sig file.
   - Able to read data from PostgreSQL for pgr_mrt().
   - Made the c++ containers and added
boost::lengauer_tarjan_dominator_tree algorithm
   for an undirected graph. But till now it returns 0 rows.
   - Added pgTap tests files with zero tests in spanningTree/mrt the
   directory that contains: mrt-edge-cases.sql, mrt-innerQuery.sql,
   no_crash_test-mrt.sql, pgr_mrt_types_check.sql.
What do I plan on doing next week?
   - Complete coding of c++ containers and add
   boost::lengauer_tarjan_dominator_tree for both the undirected graph and
   the directed graph.
   - Write some tests for no_crash_test-mrt.sql and mrt-edge-cases.sql
   - Prepare user documentation for two graph common spanning tree.
Meetings attended in this week
No meeting was scheduled.
Am I blocked on anything?
No blocking issues.
Thanks
Prakash Tiwari
links:
[1]. https://github.com/pgRouting/pgrouting/wiki/GSoC-2020-Lengauer-Tarjan-dominator-tree-and-Two-graphs-common-Spanning-Trees
[2].https://github.com/pgRouting/GSoC-pgRouting/pull/60
[3].https://github.com/pgRouting/pgrouting/wiki/GSoC-2020-Lengauer-Tarjan-dominator-tree-and-Two-graphs-common-Spanning-Trees#week-6-july-6th---july-13th-1
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20200713/17b3cd9d/attachment.html>
More information about the pgrouting-dev mailing list
