[pgrouting-dev] GSoC 2020 - Lengauer Tarjan dominator Tree and Two graphs common Spanning Trees for pgRouting - Weekly Report [Week 7]
Prakash Tiwari 85prakash2017 at gmail.com
Sun Jul 19 10:43:02 PDT 2020
Hello Everyone,
This is my weekly report for week [7] (Jul 13th -Jul 19th).The report
can also be found in project wiki [1].
What did I get done this week?
   - Created the pull request in which my weekly progress can be reviewed.[2]
   - Completed the user documentation of lengauer_tarjan_dominator_tree.
   - Fix the errors of Lengauer Tarjan dominator Tree docqueries.
   - Changed the signature of Two Graphs Common Spanning Trees from
pgr_mrt to pgr_two_graphs_common_spanning_trees and changed all the
files related to this that are mrt.c and pgrouting--3.0.0.sig.
   -  Made the c++ containers and added
boost::two_graphs_common_spanning_trees algorithm for undirected
graph.But till now it gives a lot of errors.
   - Added docqueries files inside the doc/spanningTree folder
containing doc-mrt.test.sql and doc-mrt.result.
pgr_two_graphs_common_spanning_trees up till work.
What do I plan on doing next week?
   - Complete coding of c++ containers and add
boost::lengauer_tarjan_dominator_tree for both undirected graph and
directed graph and fix all errors.
   - Write some tests for no_crash_test-mrt.sql and mrt-edge-cases.sql
   - Prepare user documentation for two graph common spanning tree.No
meeting was scheduled.
Am I blocked on anything?
No blocking issues.
Thanks
Prakash Tiwari
links:
[1].
https://github.com/pgRouting/pgrouting/wiki/GSoC-2020-Lengauer-Tarjan-dominator-tree-and-Two-graphs-common-Spanning-Trees
[2].https://github.com/pgRouting/GSoC-pgRouting/pull/64
[3].
https://github.com/pgRouting/pgrouting/wiki/GSoC-2020-Lengauer-Tarjan-dominator-tree-and-Two-graphs-common-Spanning-Trees#week-6-july-6th---july-13th-1
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20200719/69661d36/attachment-0001.html>
More information about the pgrouting-dev mailing list
