[pgrouting-dev] GSoC 2020 Coding Period Report Week 2
Himanshu Raj
raj.himanshu2 at gmail.com
Sun Jun 14 03:36:42 PDT 2020
Hello Everyone,
My Wiki [1]
My Forked Repository [2]
This is my report for *Coding Period Week 2 (June 8th - June 14th).*
- *What did I get done this week?*
- Started coding on my boost planar Graph function pgr_boyerMyrvold
in the branch named him
<https://github.com/rajhim2/GSoC-pgRouting/tree/him> in my forked
repository. Completed with coding of the function.
- Modified and added all the required files for the implementation of
my function.
- Details can be found in [3]
- The merged pull request can be found in [4]
- *What do I plan on doing next week?*
- Currently the data returned after the query is displayed
incorrectly at the respective columns. I will be fixing this bug.
- The pgTAP tests of pgr_boyerMyrvold are remaining. So, in the
coming week, I plan to add all the pgTAP tests - Server no crash test for
null parameters, parameters type check, inner query tests, and the unit
tests - one vertex, one edge, two edges, cycle with 3 edges, etc
after the
above bug is removed.
- I will also be working on the documentation of this function.
- *Am I blocked on anything?*
incorrectly at the respective columns. One of the columns is showing
garbage values. I am trying to fix this bug.
- Apart from this I don't have any blocking issues.
Regards,
Himanshu Raj
*Links:*
[1] WIKI
<https://github.com/pgRouting/pgrouting/wiki/GSoC-2020-Implementation-of-Edge-Contraction-Technique-in-pgRouting>
[2] Forked Repository <https://github.com/rajhim2/GSoC-pgRouting/tree/him>
[3]
https://github.com/pgRouting/pgrouting/wiki/GSoC-2020-Implementation-of-Edge-Contraction-Technique-in-pgRouting#week-2-june-8th---june-15th-1
[4] Merged Pull Request
<https://github.com/pgRouting/GSoC-pgRouting/pull/42>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20200614/06d6ec3a/attachment.html>
More information about the pgrouting-dev
