[pgrouting-dev] pgRouting version 3.3.2 release | FOSS4G 2022
Ashish Kumar ashishkr23438 at gmail.com
Sat Aug 27 23:50:38 PDT 2022
Hello pgRouting community,
As a part of the FOSS4G 2022 Firenze (Italy) Codesprint,
*The pgRouting Team is pleased to announce the release of pgRouting version
3.3.2*
The latest release is available at [1]
For discussions on the release, go to [2]
To see all issues & pull requests closed by this release, see the Git
closed milestone for 3.3.2 on Github. [3]
*Revised documentation*
   - Simplifying table names and table columns, for example:
      - edges instead of edge_table
   - Removing unused columns category_id and reverse_category_id.
      - combinations instead of combinations_table
      - Using PostGIS standard for geometry column.
      - geom instead of the_geom
      - Avoiding usage of functions that modify indexes, columns etc on
   tables.
      - Using pgr_extractVertices to create a routing topology
   - Restructure of the pgRouting concepts page.
*Issue fixes*
   - #2276: edgeDisjointPaths issues with start_vid and combinations
   - #2312: pgr_extractVertices error when target is not BIGINT
   - #2357: Apply clang-tidy performance
*To update your database*
Download the packaged version from your operating system, and use this
command in the database:
ALTER EXTENSION pgrouting UPDATE TO "3.3.2";
[1]. https://github.com/pgRouting/pgrouting/releases/latest
[2]. https://github.com/pgRouting/pgrouting/discussions/2359
[3].
https://github.com/pgRouting/pgrouting/issues?utf8=%E2%9C%93&q=milestone%3A%22Release%203.3.2%22
Regards,
pgRouting Team.
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20220828/31cbe49b/attachment.htm>
More information about the pgrouting-dev mailing list
