[pgrouting-dev] pgRouting version 3.3.2 release | FOSS4G 2022
Rajat Shinde rajatshinde2303 at gmail.com
Sun Aug 28 01:11:04 PDT 2022
That's amazing news. Congratulations to the pgRouting community.
Best regards,
Rajat
On Sun, Aug 28, 2022 at 8:50 AM Ashish Kumar <ashishkr23438 at gmail.com>
wrote:
> Hello pgRouting community,
> As a part of the FOSS4G 2022 Firenze (Italy) Codesprint,
> *The pgRouting Team is pleased to announce the release of pgRouting
> version 3.3.2*
> The latest release is available at [1]
> For discussions on the release, go to [2]
> To see all issues & pull requests closed by this release, see the Git
> closed milestone for 3.3.2 on Github. [3]
> *Revised documentation*
>    - Simplifying table names and table columns, for example:
>       - edges instead of edge_table
>    - Removing unused columns category_id and reverse_category_id.
>       - combinations instead of combinations_table
>       - Using PostGIS standard for geometry column.
>       - geom instead of the_geom
>       - Avoiding usage of functions that modify indexes, columns etc on
>    tables.
>       - Using pgr_extractVertices to create a routing topology
>    - Restructure of the pgRouting concepts page.
> *Issue fixes*
>    - #2276: edgeDisjointPaths issues with start_vid and combinations
>    - #2312: pgr_extractVertices error when target is not BIGINT
>    - #2357: Apply clang-tidy performance
> *To update your database*
> Download the packaged version from your operating system, and use this
> command in the database:
> ALTER EXTENSION pgrouting UPDATE TO "3.3.2";
> [1]. https://github.com/pgRouting/pgrouting/releases/latest
> [2]. https://github.com/pgRouting/pgrouting/discussions/2359
> [3].
> https://github.com/pgRouting/pgrouting/issues?utf8=%E2%9C%93&q=milestone%3A%22Release%203.3.2%22
> Regards,
> pgRouting Team.
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/pgrouting-dev
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20220828/0feb053e/attachment.htm>
More information about the pgrouting-dev mailing list
