[pgrouting-dev] Incubate pgRouting as OSGeo Project
Vicky Vergara
vicky at georepublic.de
Tue Jul 26 08:35:57 PDT 2022
Hello Incubator committee,
We are making a formal request to the incubation committee to incubate
pgRouitng.
We have read the [1], [2] and [3] and we think that most of the points
as most, if not all, are already done for pgRouting.
>From [1] pgROuting fulfils all the requirements to make the application:
- geospatial: pgRouting is a library that helps solve geospatial
problems, routing in particular.
- open source license: pgRouting is under GPLv2 for the code, and CC
BY-SA 3.0 for the documentation.
- accepts contributions: pgRouting accepts contributions from
documentation and bug fixes, up to creation of new functionality.
- source code check, with source code audit: all of pgRouting's PR needs
to be reviewed.
- open community with transparent communication and decision making
process: pgRouting has 2 mailing lists, a gitter chat and an IRC channel.
- active and healthy community with user and developer collaboration,
drawing members from several organizations for long term viability:
pgRouting has this large range of contributors.
- development supported by version control and issue tracker: pgRouting
uses github.
- developer leadership offering both transparent decision making and an
opportunity for new members to participate: pgRouting uses the
communication tools to promote this.
- user documentation and developer documentation: pgRouting has both
- release procedure covering both the release process and documented
testing process: We have both, a procedure document, and the tests are
carried out on github actions.
In the next mail, the link to the questionnaire [2] on a trac ticket
will be given.
Thanks.
[1] https://www.osgeo.org/about/committees/incubation/
[2] https://www.osgeo.org/about/committees/incubation/application/
[3] https://www.osgeo.org/wp-content/uploads/graduation_checklist.pdf
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky at georepublic.de
Web: https://georepublic.info
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20220726/7c8bea55/attachment.htm>
More information about the pgrouting-dev
