[pgrouting-dev] Incubate pgRouting as OSGeo Project
    Vicky Vergara
    vicky at georepublic.de
    Tue Jul 26 10:52:36 PDT 2022
Hello committee:
The incubation questionnaire can be found on [4]
Regards
[4] https://trac.osgeo.org/osgeo/ticket/2784
On Tue, Jul 26, 2022 at 10:35 AM Vicky Vergara <vicky at georepublic.de> wrote:
> Hello Incubator committee,
> We are making a formal request to the incubation committee to incubate pgRouitng.
> We have read the [1], [2] and [3] and we think that most of the points as most, if not all, are already done for pgRouting.
> From [1] pgROuting fulfils all the requirements to make the application:
>    - geospatial: pgRouting is a library that helps solve geospatial
>    problems, routing in particular.
>    - open source license: pgRouting is under GPLv2 for the code, and CC
>    BY-SA 3.0 for the documentation.
>    - accepts contributions: pgRouting accepts contributions from
>    documentation and bug fixes, up to creation of new functionality.
>    - source code check, with source code audit: all of pgRouting's PR
>    needs to be reviewed.
>    - open community with transparent communication and decision making
>    process: pgRouting has 2 mailing lists, a gitter chat and an IRC channel.
>    - active and healthy community with user and developer collaboration,
>    drawing members from several organizations for long term viability:
>    pgRouting has this large range of contributors.
>    - development supported by version control and issue tracker:
>    pgRouting uses github.
>    - developer leadership offering both transparent decision making and
>    an opportunity for new members to participate: pgRouting uses the
>    communication tools to promote this.
>    - user documentation and developer documentation: pgRouting has both
>    - release procedure covering both the release process and documented
>    testing process: We have both, a procedure document, and the tests are
>    carried out on github actions.
> In the next mail, the link to the questionnaire [2] on a trac ticket will be given.
> Thanks.
> [1] https://www.osgeo.org/about/committees/incubation/
> [2] https://www.osgeo.org/about/committees/incubation/application/
> [3] https://www.osgeo.org/wp-content/uploads/graduation_checklist.pdf
> Georepublic UG (haftungsbeschränkt)
> Salzmannstraße 44,
> 81739 München, Germany
> Vicky Vergara
> Operations Research
> eMail: vicky at georepublic.de
> Web: https://georepublic.info
> Tel: +49 (089) 4161 7698-1
> Fax: +49 (089) 4161 7698-9
> Commercial register: Amtsgericht München, HRB 181428
> CEO: Daniel Kastl
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20220726/ea6454e3/attachment.htm>
More information about the pgrouting-dev
