[pgrouting-dev] [Incubator] Incubate pgRouting as OSGeo Project
Vicky Vergara
vicky at georepublic.de
Mon Oct 24 15:28:07 PDT 2022
Hello incubation committee
Sorry for the delay, finally the pgRouting code sprint has been organized.
https://www.osgeo.org/events/pgrouting-codesprint/
Regards
Vicky
On Fri, Aug 12, 2022 at 7:12 PM Jody Garnett <jody.garnett at gmail.com> wrote:
> Yep, and we await your sprint planning :)
> On Fri, Aug 12, 2022 at 10:36 AM Vicky Vergara <vicky at georepublic.de>
> wrote:
>> Hello Incubator committee,
>> Just as a reminder we made a request for funding:
>> https://lists.osgeo.org/pipermail/incubator/2022-January/004454.html
>> Regards
>> On Wed, Aug 10, 2022 at 7:10 PM Vicky Vergara <vicky at georepublic.de>
>> wrote:
>>> Hi Incubator committee,
>>> Yes we do have a mentor.
>>> Angelos Tzotsos.
>>> Regards
>>> Note: The WIP questionnaire does have the question about the mentor.
>>> On Wed, Aug 10, 2022 at 1:37 AM Jody Garnett <jody.garnett at gmail.com>
>>> wrote:
>>>> Wow that is great,
>>>> Thanks for the application.
>>>> Did you have a mentor or mind? Or can you reach out to the osgeo
>>>> community for a volunteer?
>>>> Jody
>>>> On Tue, Jul 26, 2022 at 10:52 AM Vicky Vergara <vicky at georepublic.de>
>>>> wrote:
>>>>> Hello committee:
>>>>> The incubation questionnaire can be found on [4]
>>>>> Regards
>>>>> [4] https://trac.osgeo.org/osgeo/ticket/2784
>>>>> On Tue, Jul 26, 2022 at 10:35 AM Vicky Vergara <vicky at georepublic.de>
>>>>>> We are making a formal request to the incubation committee to incubate pgRouitng.
>>>>>> We have read the [1], [2] and [3] and we think that most of the points as most, if not all, are already done for pgRouting.
>>>>>> From [1] pgROuting fulfils all the requirements to make the application:
>>>>>> - geospatial: pgRouting is a library that helps solve geospatial
>>>>>> problems, routing in particular.
>>>>>> - open source license: pgRouting is under GPLv2 for the code, and CC
>>>>>> BY-SA 3.0 for the documentation.
>>>>>> - accepts contributions: pgRouting accepts contributions from
>>>>>> documentation and bug fixes, up to creation of new functionality.
>>>>>> - source code check, with source code audit: all of pgRouting's
>>>>>> PR needs to be reviewed.
>>>>>> - open community with transparent communication and decision
>>>>>> making process: pgRouting has 2 mailing lists, a gitter chat and an IRC
>>>>>> channel.
>>>>>> - active and healthy community with user and developer
>>>>>> collaboration, drawing members from several organizations for long term
>>>>>> viability: pgRouting has this large range of contributors.
>>>>>> - development supported by version control and issue tracker:
>>>>>> pgRouting uses github.
>>>>>> - developer leadership offering both transparent decision making
>>>>>> and an opportunity for new members to participate: pgRouting uses the
>>>>>> communication tools to promote this.
>>>>>> - user documentation and developer documentation: pgRouting has
>>>>>> both
>>>>>> - release procedure covering both the release process and
>>>>>> documented testing process: We have both, a procedure document, and the
>>>>>> tests are carried out on github actions.
>>>>>> In the next mail, the link to the questionnaire [2] on a trac ticket will be given.
>>>>>> Thanks.
>>>>>> [1] https://www.osgeo.org/about/committees/incubation/
>>>>>> [2] https://www.osgeo.org/about/committees/incubation/application/
>>>>>> [3] https://www.osgeo.org/wp-content/uploads/graduation_checklist.pdf
>>>>>> Georepublic UG (haftungsbeschränkt)Salzmannstraße 44,
>>>>>> 81739 München, Germany <https://www.google.com/maps/search/Salzmannstra%C3%9Fe+44,+%0D%0A81739+M%C3%BCnchen,+Germany?entry=gmail&source=g>
>>>>>> Vicky Vergara
>>>>>> Operations Research
>>>>>> eMail: vicky at georepublic.de
>>>>>> Web: https://georepublic.info
>>>>>> Tel: +49 (089) 4161 7698-1
>>>>>> Fax: +49 (089) 4161 7698-9
>>>>>> Commercial register: Amtsgericht München, HRB 181428
>>>>>> CEO: Daniel Kastl
>>>>> Vicky Vergara
>>>>> Operations Research
>>>>> CEO: Daniel Kastl
>>>>> _______________________________________________
>>>>> Incubator mailing list
>>>>> Incubator at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/incubator
>>> Vicky Vergara
>>> Operations Research
>>> CEO: Daniel Kastl
>> Vicky Vergara
>> Operations Research
>> CEO: Daniel Kastl
> Jody Garnett
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20221024/0529d1a9/attachment.htm>
More information about the pgrouting-dev
