[pgrouting-dev] [Incubator] Incubate pgRouting as OSGeo Project
Vicky Vergara
vicky at georepublic.de
Mon Oct 24 15:29:54 PDT 2022
Sorry,
I messed up the link:
https://www.osgeo.org/events/pgrouting-codesprint-2022/
Regards
On Mon, Oct 24, 2022 at 5:28 PM Vicky Vergara <vicky at georepublic.de> wrote:
> Hello incubation committee
> Sorry for the delay, finally the pgRouting code sprint has been organized.
> https://www.osgeo.org/events/pgrouting-codesprint/
> Regards
> Vicky
> On Fri, Aug 12, 2022 at 7:12 PM Jody Garnett <jody.garnett at gmail.com>
> wrote:
>> Yep, and we await your sprint planning :)
>> On Fri, Aug 12, 2022 at 10:36 AM Vicky Vergara <vicky at georepublic.de>
>> wrote:
>>> Hello Incubator committee,
>>> Just as a reminder we made a request for funding:
>>> https://lists.osgeo.org/pipermail/incubator/2022-January/004454.html
>>> Regards
>>> On Wed, Aug 10, 2022 at 7:10 PM Vicky Vergara <vicky at georepublic.de>
>>> wrote:
>>>> Hi Incubator committee,
>>>> Yes we do have a mentor.
>>>> Angelos Tzotsos.
>>>> Regards
>>>> Note: The WIP questionnaire does have the question about the mentor.
>>>> On Wed, Aug 10, 2022 at 1:37 AM Jody Garnett <jody.garnett at gmail.com>
>>>> wrote:
>>>>> Wow that is great,
>>>>> Thanks for the application.
>>>>> Did you have a mentor or mind? Or can you reach out to the osgeo
>>>>> community for a volunteer?
>>>>> Jody
>>>>> On Tue, Jul 26, 2022 at 10:52 AM Vicky Vergara <vicky at georepublic.de>
>>>>> wrote:
>>>>>> Hello committee:
>>>>>> The incubation questionnaire can be found on [4]
>>>>>> Regards
>>>>>> [4] https://trac.osgeo.org/osgeo/ticket/2784
>>>>>> On Tue, Jul 26, 2022 at 10:35 AM Vicky Vergara <vicky at georepublic.de>
>>>>>>> We are making a formal request to the incubation committee to incubate pgRouitng.
>>>>>>> We have read the [1], [2] and [3] and we think that most of the points as most, if not all, are already done for pgRouting.
>>>>>>> From [1] pgROuting fulfils all the requirements to make the application:
>>>>>>> - geospatial: pgRouting is a library that helps solve geospatial
>>>>>>> problems, routing in particular.
>>>>>>> - open source license: pgRouting is under GPLv2 for the code,
>>>>>>> and CC BY-SA 3.0 for the documentation.
>>>>>>> - accepts contributions: pgRouting accepts contributions from
>>>>>>> documentation and bug fixes, up to creation of new functionality.
>>>>>>> - source code check, with source code audit: all of pgRouting's
>>>>>>> PR needs to be reviewed.
>>>>>>> - open community with transparent communication and decision
>>>>>>> making process: pgRouting has 2 mailing lists, a gitter chat and an IRC
>>>>>>> channel.
>>>>>>> - active and healthy community with user and developer
>>>>>>> collaboration, drawing members from several organizations for long term
>>>>>>> viability: pgRouting has this large range of contributors.
>>>>>>> - development supported by version control and issue tracker:
>>>>>>> pgRouting uses github.
>>>>>>> - developer leadership offering both transparent decision making
>>>>>>> and an opportunity for new members to participate: pgRouting uses the
>>>>>>> communication tools to promote this.
>>>>>>> - user documentation and developer documentation: pgRouting has
>>>>>>> both
>>>>>>> - release procedure covering both the release process and
>>>>>>> documented testing process: We have both, a procedure document, and the
>>>>>>> tests are carried out on github actions.
>>>>>>> In the next mail, the link to the questionnaire [2] on a trac ticket will be given.
>>>>>>> Thanks.
>>>>>>> [1] https://www.osgeo.org/about/committees/incubation/
>>>>>>> [2] https://www.osgeo.org/about/committees/incubation/application/
>>>>>>> [3] https://www.osgeo.org/wp-content/uploads/graduation_checklist.pdf
>>>>>>> Georepublic UG (haftungsbeschränkt)Salzmannstraße 44,
>>>>>>> 81739 München, Germany <https://www.google.com/maps/search/Salzmannstra%C3%9Fe+44,+%0D%0A81739+M%C3%BCnchen,+Germany?entry=gmail&source=g>
>>>>>>> Vicky Vergara
>>>>>>> Operations Research
>>>>>>> eMail: vicky at georepublic.de
>>>>>>> Web: https://georepublic.info
>>>>>>> Tel: +49 (089) 4161 7698-1
>>>>>>> Fax: +49 (089) 4161 7698-9
>>>>>>> Commercial register: Amtsgericht München, HRB 181428
>>>>>>> CEO: Daniel Kastl
>>>>>> Vicky Vergara
>>>>>> Operations Research
>>>>>> CEO: Daniel Kastl
>>>>>> _______________________________________________
>>>>>> Incubator mailing list
>>>>>> Incubator at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/incubator
>>>> Vicky Vergara
>>>> Operations Research
>>>> CEO: Daniel Kastl
>>> Vicky Vergara
>>> Operations Research
>>> CEO: Daniel Kastl
>> Jody Garnett
> Salzmannstraße 44,
> Vicky Vergara
> Operations Research
> CEO: Daniel Kastl
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20221024/ec4abdea/attachment-0001.htm>
More information about the pgrouting-dev
