[pgrouting-dev] [Incubator] Incubate pgRouting as OSGeo Project
Regina Obe
lr at pcorp.us
Wed Oct 26 20:55:00 PDT 2022
Jody,
Vicky will be physically present at the code sprint.
She's put a lot of work into getting all things ready to go for the incubation.
I calculate $3000 should cover code sprint and travel expenses and work Vicky's already done.
The code sprint is planned for just one day and will be extended if extra time is needed. Vicky will be working with some of the committers in Japan on later days.
If approved, send the money to Vicky.
Thanks,
Regina
On Mon, Oct 24, 2022 at 8:07 PM Jody Garnett <jody.garnett at gmail.com> wrote:
I just noticed your second link - that event is *days* away....
- November 8th / November 8th
- 9:00 am
- Kobe, Japan
So we best make a motion now; do you actually have an event budget and can put funds to good use?
Jody Garnett
On Mon, 24 Oct 2022 at 18:04, Jody Garnett <jody.garnett at gmail.com> wrote:
Not a problem:
Is the funding request still the same?
This year hopefully we will apply for pgRouting to become an OSGeo Project.
For this matter we would like a budget of $4000 dollars, which would be
used to gather the team for a sprint, mainly traveling expenses.
(preferably on the OSGeo code sprint, if done face to face, which is a week
long)
Checking our approved budget: We requested $8000 in the hopes additional projects (zoo?) would also be planning an incubation sprint. Looks like we were authorized for $6000.
I have not been tracking osgeo sprint planning; did you have an event in mind? While incubation committee has the above budget available (and we can make a motion to allocate funds) you may wish also approach the board or travel grant fund if appropriate.
Jody
Jody Garnett
On Mon, 24 Oct 2022 at 15:30, Vicky Vergara <vicky at georepublic.de> wrote:
Sorry,
I messed up the link:
https://www.osgeo.org/events/pgrouting-codesprint-2022/
Regards
On Mon, Oct 24, 2022 at 5:28 PM Vicky Vergara <vicky at georepublic.de> wrote:
Hello incubation committee
Sorry for the delay, finally the pgRouting code sprint has been organized.
https://www.osgeo.org/events/pgrouting-codesprint/
Regards
Vicky
On Fri, Aug 12, 2022 at 7:12 PM Jody Garnett <jody.garnett at gmail.com> wrote:
Yep, and we await your sprint planning :)
On Fri, Aug 12, 2022 at 10:36 AM Vicky Vergara <vicky at georepublic.de> wrote:
Hello Incubator committee,
Just as a reminder we made a request for funding:
https://lists.osgeo.org/pipermail/incubator/2022-January/004454.html
Regards
On Wed, Aug 10, 2022 at 7:10 PM Vicky Vergara <vicky at georepublic.de> wrote:
Hi Incubator committee,
Yes we do have a mentor.
Angelos Tzotsos.
Regards
Note: The WIP questionnaire does have the question about the mentor.
On Wed, Aug 10, 2022 at 1:37 AM Jody Garnett <jody.garnett at gmail.com> wrote:
Wow that is great,
Thanks for the application.
Did you have a mentor or mind? Or can you reach out to the osgeo community for a volunteer?
Jody
On Tue, Jul 26, 2022 at 10:52 AM Vicky Vergara <vicky at georepublic.de> wrote:
Hello committee:
The incubation questionnaire can be found on [4]
Regards
[4] https://trac.osgeo.org/osgeo/ticket/2784
On Tue, Jul 26, 2022 at 10:35 AM Vicky Vergara <vicky at georepublic.de> wrote:
We are making a formal request to the incubation committee to incubate pgRouitng.
We have read the [1], [2] and [3] and we think that most of the points as most, if not all, are already done for pgRouting.
>From [1] pgROuting fulfils all the requirements to make the application:
• geospatial: pgRouting is a library that helps solve geospatial problems, routing in particular.
• open source license: pgRouting is under GPLv2 for the code, and CC BY-SA 3.0 for the documentation.
• accepts contributions: pgRouting accepts contributions from documentation and bug fixes, up to creation of new functionality.
• source code check, with source code audit: all of pgRouting's PR needs to be reviewed.
• open community with transparent communication and decision making process: pgRouting has 2 mailing lists, a gitter chat and an IRC channel.
• active and healthy community with user and developer collaboration, drawing members from several organizations for long term viability: pgRouting has this large range of contributors.
• development supported by version control and issue tracker: pgRouting uses github.
• developer leadership offering both transparent decision making and an opportunity for new members to participate: pgRouting uses the communication tools to promote this.
• user documentation and developer documentation: pgRouting has both
• release procedure covering both the release process and documented testing process: We have both, a procedure document, and the tests are carried out on github actions.
In the next mail, the link to the questionnaire [2] on a trac ticket will be given.
Thanks.
[1] https://www.osgeo.org/about/committees/incubation/
[2] https://www.osgeo.org/about/committees/incubation/application/
[3] https://www.osgeo.org/wp-content/uploads/graduation_checklist.pdf
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky at georepublic.de
Web: https://georepublic.info
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
Incubator mailing list
Incubator at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/incubator
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
Jody Garnett
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
More information about the pgrouting-dev
