[pgrouting-dev] Patch for CMakeLists.txt to support more Postgres variants
Sandeep Thakkar
sandeep.thakkar at enterprisedb.com
Tue Sep 6 21:19:54 PDT 2022
Hi
I created a new pull request for the same at
https://github.com/pgRouting/pgrouting/pull/2362. Can someone please review
it?
On Mon, Sep 5, 2022 at 9:41 AM Sandeep Thakkar <
sandeep.thakkar at enterprisedb.com> wrote:
> Hi,
> I was trying to compile pgRouting-3.3.1 against EnterpriseDB Postgres
> (EPAS) on Rocky Linux 8 instance and the build failed with the following
> error:
> CMake Error at CMakeLists.txt:183 (message):
>> PostgreSQL 9.2.0 or greater is required.
> Attached is the patch for CMakeLists.txt to support additional Postgres
> variants along with community PostgreSQL. If there is a better way to
> submit the patch (https://docs.pgrouting.org/doxygen/ ?) then do let me
> know and I'll be happy to do that.
>> The current logic to get the version from the version string depends
>> on the position (11) which may not work with other postgres variants
>> because of the different strings they may carry like EnterpriseDB for
>> an example.
> So instead of string substring, use string regex match to get the
>> version. Also, move up the code to replace the strings alpha/beta/rc
>> a bit to support the patch
> Tested on Linux
> Sandeep Thakkar
Sandeep Thakkar
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20220907/bf0e78aa/attachment.htm>
More information about the pgrouting-dev
