[pgrouting-dev] Patch for CMakeLists.txt to support more Postgres variants
Sandeep Thakkar sandeep.thakkar at enterprisedb.com
Sun Sep 4 21:11:27 PDT 2022
I was trying to compile pgRouting-3.3.1 against EnterpriseDB Postgres
(EPAS) on Rocky Linux 8 instance and the build failed with the following
error:
CMake Error at CMakeLists.txt:183 (message):
>    PostgreSQL 9.2.0 or greater is required.
Attached is the patch for CMakeLists.txt to support additional Postgres
variants along with community PostgreSQL. If there is a better way to
submit the patch (https://docs.pgrouting.org/doxygen/ ?) then do let me
know and I'll be happy to do that.
>    The current logic to get the version from the version string depends
>     on the position (11) which may not work with other postgres variants
>     because of the different strings they may carry like EnterpriseDB for
>     an example.
    So instead of string substring, use string regex match to get the
>     version. Also, move up the code to replace the strings alpha/beta/rc
>     a bit to support the patch
    Tested on Linux
Sandeep Thakkar
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20220905/2a8ad4b7/attachment.htm>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20220905/2a8ad4b7/attachment.obj>
More information about the pgrouting-dev mailing list
