[pgrouting-users] ERROR: relation with OID 156906 does not exist
Anton Patrushev anton at orkney.co.jp
Wed Sep 17 20:39:14 EDT 2008
Hi Steve,
 It should be enough just to exit PostreSQL console and enter again
 (which means to start a new session). It is quite known issue with
 temporary tables in PostgreSQL (see
 http://www.postgresql.org/docs/faqs.FAQ.html#item4.19).
 Anton.
 On 9/18/08, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
 > Hi all,
 >  I have run into a really annoying issue. When I want to rebuild the
 >  vertices_tmp table. I do something like:
 >  drop index source_idx;
 >  drop index target_idx;
 >  update st set source=null, target=null;
 >  delete from geometry_columns where f_table_name='vertices_tmp';
 >  vacuum analyze;
 >  select assign_vertex_id('st', 0.0000005, 'the_geom', 'gid');
 >  create unique index vertices_tmp_id_idx on vertices_tmp using btree(id);
 >  create index source_idx on st using btree(source);
 >  create index target_idx on st using btree(target);
 >  vacuum analyze;
 >  But I get this error:
 >  routing=# select assign_vertex_id('st', 0.0000005, 'the_geom', 'gid');
 >  NOTICE:  CREATE TABLE will create implicit sequence
 >  "vertices_tmp_id_seq" for serial column "vertices_tmp.id"
 >  CONTEXT:  SQL statement "CREATE TABLE vertices_tmp (id serial)"
 >  PL/pgSQL function "assign_vertex_id" line 21 at execute statement
 >  CONTEXT:  SQL statement "SELECT id, the_geom FROM vertices_tmp WHERE
 >  expand( $1 ,  $2 ) && the_geom and distance(the_geom,  $1 ) <  $2 "
 >  PL/pgSQL function "point_to_id" line 7 at SQL statement
 >  PL/pgSQL function "assign_vertex_id" line 61 at assignment
 >  The only way I have found to clear this error and get things to run
 >  again, is to reload function assign_vertex_id().
 >  What is causing it? and how can I avoid it in the future?
 >  Thanks,
 >    -Steve
 >  _______________________________________________
 >  Pgrouting-users mailing list
 >  Pgrouting-users at lists.postlbs.org
 >  http://lists.postlbs.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
