[pgrouting-users] ERROR: relation with OID 156906 does not exist
Anton Patrushev
anton.patrushev at gmail.com
Wed Sep 17 20:30:51 EDT 2008
Hi Steve,
It should be enough just to exit PostreSQL console and enter again
(which means to start a new session). It is quite known issue with
temporary tables in PostgreSQL (see
http://www.postgresql.org/docs/faqs.FAQ.html#item4.19).
Anton.
On 9/18/08, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> Hi all,
> I have run into a really annoying issue. When I want to rebuild the
> vertices_tmp table. I do something like:
> drop index source_idx;
> drop index target_idx;
> update st set source=null, target=null;
> delete from geometry_columns where f_table_name='vertices_tmp';
> vacuum analyze;
> select assign_vertex_id('st', 0.0000005, 'the_geom', 'gid');
> create unique index vertices_tmp_id_idx on vertices_tmp using btree(id);
> create index source_idx on st using btree(source);
> create index target_idx on st using btree(target);
> vacuum analyze;
> But I get this error:
> routing=# select assign_vertex_id('st', 0.0000005, 'the_geom', 'gid');
> NOTICE: CREATE TABLE will create implicit sequence
> "vertices_tmp_id_seq" for serial column "vertices_tmp.id"
> CONTEXT: SQL statement "CREATE TABLE vertices_tmp (id serial)"
> PL/pgSQL function "assign_vertex_id" line 21 at execute statement
> CONTEXT: SQL statement "SELECT id, the_geom FROM vertices_tmp WHERE
> expand( $1 , $2 ) && the_geom and distance(the_geom, $1 ) < $2 "
> PL/pgSQL function "point_to_id" line 7 at SQL statement
> PL/pgSQL function "assign_vertex_id" line 61 at assignment
> The only way I have found to clear this error and get things to run
> again, is to reload function assign_vertex_id().
> What is causing it? and how can I avoid it in the future?
> Thanks,
> -Steve
> Pgrouting-users mailing list
> Pgrouting-users at lists.postlbs.org
> http://lists.postlbs.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
