[pgrouting-users] problem with pgrouting.
Daniel Kastl
kastl at orkney.co.jp
Wed Feb 4 22:51:16 EST 2009
Valeria,
This depends on your data. Distance might be your current cost already.
You can get the total distance with SELECT sum(length(rt.the_geom)) ... .
If you want to have time you might need a "speed" attribute for your
road link table.
Daniel
Valeria Muñoz schrieb:
> how can i get the distance,time, if you have to turn right o to turn
> left??
> RG
> 2009/2/4 Valeria Muñoz <valemunoz at gmail.com <mailto:valemunoz at gmail.com>>
> Stephen you are right i change to :
> SELECT assign_vertex_id('edges', 0.000001, 'the_geom', 'gid');
> and works!!! thanks!!
> 2009/2/4 Stephen Woodbridge <woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>>
> Valeria,
> What projection is your shapefile in? it looks like WGS84 or
> NAD83 from your coordinates below. So when you did:
> SELECT assign_vertex_id('edges', 0.001, 'the_geom', 'gid');
> you should probably have done:
> The tolerance needs to be in the units of your data. This will
> probably give better results.
> You should probably drop the database and start over with a
> new load and use the statement above when you get to that step.
> -Steve
> Valeria Muñoz wrote:
> Hi
> I followed a little tutorial works perfectly with the
> shapefile from the example, but to use mine the result is
> not expected, generating lines are not continuous, I think
> I missing some coordinates or something to work with my
> shapefile.
> tutorial url
> http://www.utdallas.edu/~ama054000/rt_tutorial.html
> <http://www.utdallas.edu/%7Eama054000/rt_tutorial.html>
> query:
> the query is optimal path between 887 y 852. :
> SELECT rt.gid, AsText(rt.the_geom) AS wkt,
> length(rt.the_geom) AS length, calle.gid
> FROM calle,
> (SELECT gid, the_geom
> FROM dijkstra_sp_delta(
> 'calle',
> 887,
> 852,
> 3000)
> ) as rt
> WHERE calle.gid=rt.gid;
> result:
> "gid";"wkt";"length";"gid"
> 4389;"MULTILINESTRING((-71.1951327440651
> -30.5911350429583,-71.1957462426904
> -30.5912128948402,-71.1957861853043
> -30.591219747929,-71.1958400125164
> -30.591211719682))";0.000713367403530106;4389
> 4603;"MULTILINESTRING((-71.1939954028678
> -30.5921681162637,-71.1939834234752
> -30.5922241673576,-71.1938231446269
> -30.5925509466888))";0.000421286769021393;4603
> 4331;"MULTILINESTRING((-71.1950174992082
> -30.5919506007811,-71.1950526139385
> -30.5916919152203))";0.000261057969957178;4331
> 4608;"MULTILINESTRING((-71.1938231446269
> -30.5925509466888,-71.1937648360013
> -30.5926358138883))";0.00010296765211197;4608
> RG
> attached image.
> please help!!..
> Pgrouting-users mailing list
> Pgrouting-users at lists.postlbs.org
> <mailto:Pgrouting-users at lists.postlbs.org>
> http://lists.postlbs.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
