[pgrouting-users] problem with pgrouting.
Valeria Muñoz
valemunoz at gmail.com
Thu Feb 5 10:01:57 EST 2009
Daniel
what type of measure returns the function length()?, my result
was:0.00208418695629
I have the SPEED field, you know how I can give instructions such as turn
right or left?
RG
2009/2/5 Daniel Kastl <kastl at orkney.co.jp>
> Valeria,
> This depends on your data. Distance might be your current cost already.
> You can get the total distance with SELECT sum(length(rt.the_geom)) ... .
> If you want to have time you might need a "speed" attribute for your
> road link table.
> Daniel
> Valeria Muñoz schrieb:
> > how can i get the distance,time, if you have to turn right o to turn
> > left??
> > RG
> > 2009/2/4 Valeria Muñoz <valemunoz at gmail.com <mailto:valemunoz at gmail.com
> > Stephen you are right i change to :
> > SELECT assign_vertex_id('edges', 0.000001, 'the_geom', 'gid');
> > and works!!! thanks!!
> > 2009/2/4 Stephen Woodbridge <woodbri at swoodbridge.com
> > <mailto:woodbri at swoodbridge.com>>
> > Valeria,
> > What projection is your shapefile in? it looks like WGS84 or
> > NAD83 from your coordinates below. So when you did:
> > SELECT assign_vertex_id('edges', 0.001, 'the_geom', 'gid');
> > you should probably have done:
> > The tolerance needs to be in the units of your data. This will
> > probably give better results.
> > You should probably drop the database and start over with a
> > new load and use the statement above when you get to that step.
> > -Steve
> > Valeria Muñoz wrote:
> > Hi
> > I followed a little tutorial works perfectly with the
> > shapefile from the example, but to use mine the result is
> > not expected, generating lines are not continuous, I think
> > I missing some coordinates or something to work with my
> > shapefile.
> > tutorial url
> > http://www.utdallas.edu/~ama054000/rt_tutorial.html
> > <http://www.utdallas.edu/%7Eama054000/rt_tutorial.html<http://www.utdallas.edu/~ama054000/rt_tutorial.html>
> > query:
> > the query is optimal path between 887 y 852. :
> > SELECT rt.gid, AsText(rt.the_geom) AS wkt,
> > length(rt.the_geom) AS length, calle.gid
> > FROM calle,
> > (SELECT gid, the_geom
> > FROM dijkstra_sp_delta(
> > 'calle',
> > 887,
> > 852,
> > 3000)
> > ) as rt
> > WHERE calle.gid=rt.gid;
> > result:
> > "gid";"wkt";"length";"gid"
> > 4389;"MULTILINESTRING((-71.1951327440651
> > -30.5911350429583,-71.1957462426904
> > -30.5912128948402,-71.1957861853043
> > -30.591219747929,-71.1958400125164
> > -30.591211719682))";0.000713367403530106;4389
> > 4603;"MULTILINESTRING((-71.1939954028678
> > -30.5921681162637,-71.1939834234752
> > -30.5922241673576,-71.1938231446269
> > -30.5925509466888))";0.000421286769021393;4603
> > 4331;"MULTILINESTRING((-71.1950174992082
> > -30.5919506007811,-71.1950526139385
> > -30.5916919152203))";0.000261057969957178;4331
> > 4608;"MULTILINESTRING((-71.1938231446269
> > -30.5925509466888,-71.1937648360013
> > -30.5926358138883))";0.00010296765211197;4608
> > RG
> > attached image.
> > please help!!..
> > Pgrouting-users mailing list
> > Pgrouting-users at lists.postlbs.org
> > <mailto:Pgrouting-users at lists.postlbs.org>
> > http://lists.postlbs.org/mailman/listinfo/pgrouting-users
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20090205/97b278c3/attachment.html
More information about the Pgrouting-users
