[pgrouting-users] osm2pgrouting import problem
Anton Patrushev anton at orkney.co.jp
Tue Jul 14 05:37:25 EDT 2009
Kai,
Try to execute patch -p0 -i db.patch in your  /home/work/osm2pgrouting
Anton.
On Tue, Jul 14, 2009 at 6:27 PM, Kai Behncke<Kai-Behncke at gmx.de> wrote:
> Hi Anton,
> thank you very much.
> This patch-thing is really very new to me, I made a couple of tests but without success so far.
> I have the directory /home/work/osm2pgrouting where I also copied
> the file db.patch in.
> Then I tried e.g. "patch /home/work/osm2pgrouting/db.patch"
> (but after that I only get a blinking cursor and osm2pgrouting works still "the old way").
> Can anybody bring some light into it, please?
> Thank you again, Kai
> -------- Original-Nachricht --------
>> Datum: Tue, 14 Jul 2009 15:36:44 +0900
>> Von: Anton Patrushev <anton at orkney.co.jp>
>> An: pgrouting-users at lists.postlbs.org
>> Betreff: Re: [pgrouting-users] osm2pgrouting import problem
>> Hi Kai,
>> No, you need to use patch command.
>> Here is brief tutorial on how to make and apply patches in Linux.
>> http://www.linuxforums.org/articles/using-diff-and-patch_80.html
>> Anton.
>> On Tue, Jul 14, 2009 at 3:10 PM, Kai Behncke<Kai-Behncke at gmx.de> wrote:
>> > Dear Vladislav,
>> > thank you very much for that :-)
>> >> fell free to ask any questions,
>> > My question is: How do I integrate that patch?
>> > I just rename that file to "OSMDocument.h" and copy it into /core/src ?
>> > And after that I run make, correct?
>> > Thank you very much, Kai
>> >> Datum: Tue, 14 Jul 2009 00:02:56 +0400
>> >> Von: Vladislav Shikhov <vladshikhov at gmail.com>
>> >> An: Kai Behncke <Kai-Behncke at gmx.de>, pgrouting-users at lists.postlbs.org
>> >> Hello, all.
>> >> Fist of all I'd like to admit that this patch doesn't solve all the
>> >> osm2pgroute problems. Please, take it as is.
>> >> The main idea was to store nodes not in the memory, but in the DB and
>> >> select them on demand.
>> >> It makes "-clean" arg unusable, but I introduce a new arg "-stage"
>> >> with values starting from 0 (default). Now you can interrupt
>> >> osm2pgroute after the message "Split ways" and rerun it again with
>> >> "-stage 2", it will reuse previously imported nodes.
>> >> regards,
>> >> Vladislav Shikhov
>> >> On Mon, Jul 13, 2009 at 3:24 PM, Kai Behncke<Kai-Behncke at gmx.de> wrote:
>> >> > Hi Vladislav,
>> >> > would you please post your patch via the list, please?
>> >> > That would be very helpful for us all. :-)
>> >> >> Datum: Sun, 12 Jul 2009 21:51:32 +0400
>> >> >> I've made some trivial patches for osm2pgrouting, so now it takes
>> >> >> about 4 hours to import whole Russia in to DB on 2 cores 2.3 Ghz
>> >> >> Athlon &1 Gb memory. Switch on you brain, it rather simple.
>> >> >> On Sun, Jul 12, 2009 at 3:59 PM, Kai Behncke<Kai-Behncke at gmx.de>
>> wrote:
>> >> >> > Dear users,
>> >> >> > I tried it as well with the Germany-osm-data (600 MB) on a pc with
>> >> >> > 4 processors, 4 GB RAM and 7GB Swap), but it failed after 14
>> hours.
>> >> >> > I trief then to load in single counties (Bundesländer). Always
>> the
>> >> >> first one works
>> >> >> > but after that (e.g. first one is "Hamburg", second one "Bremen")
>> >> only
>> >> >> nodes are inserted (and no ways). Is this a known error/issue.
>> >> >> > What would you recommend to get All the data of one country in a
>> >> >> database?
>> >> >> >> Datum: Mon, 29 Jun 2009 09:35:45 +0900
>> >> >> >> Von: Daniel Kastl <kastl at orkney.co.jp>
>> >> >> >> Hi Eike,
>> >> >> >> You probably run into this issue:
>> >> >> http://pgrouting.postlbs.org/ticket/140
>> >> >> >> If you can try it with a smaller dataset for testing and it
>> worked,
>> >> >> then
>> >> >> >> this is the case. If it still doesn't work then please let us
>> know.
>> >> >> >> The original author of osm2pgrouting said he's currently working
>> on
>> >> >> this
>> >> >> >> issue as time allows.
>> >> >> >> Daniel
>> >> >> >> PS: Once I tried a little larger dataset I just increased my SWAP
>> >> >> >> partition and it worked then, but I don't know how large the
>> German
>> >> >> data
>> >> >> >> is. It's not a nice solution anyway.
>> >> >> >> Eike Lüders schrieb:
>> >> >> >> > Hello everybody!
>> >> >> >> > I've got a problem with osm2pgrouting.
>> >> >> >> > I downloaded the osm file for germany from here:
>> >> >> >> > http://download.geofabrik.de/osm/europe/germany.osm.bz2
>> >> >> >> > If I try to run osm2pgrouting on it now by typing
>> >> >> >> > ./osm2pgrouting -file germany.osm -conf mapconfig.xml -dbname
>> >> routing
>> >> >> >> > -user postgres -passwd postgres -clean
>> >> >> >> > into the shell it gives me the following information, but
>> nothing
>> >> >> >> > happes (the db information above are correct!).
>> >> >> >> > There is no error message or something like that.
>> >> >> >> > I hope anybody know how to solve this problem.
>> >> >> >> > host=127.0.0.1 user=postgres dbname=routing port=5432
>> >> >> password=postgres
>> >> >> >> > connection success
>> >> >> >> > Trying to load config file mapconfig.xml
>> >> >> >> > Trying to parse config
>> >> >> >> > SE for <configuration>
>> >> >> >> > SE for <type>
>> >> >> >> > SE for <class>
>> >> >> >> > class name = motorway
>> >> >> >> > class id = 101
>> >> >> >> > class id = 101 name = motorway added to type name=highway
>> >> >> >> > SE for <class>
>> >> >> >> > class name = motorway_link
>> >> >> >> > class id = 102
>> >> >> >> > class id = 102 name = motorway_link added to type name=highway
>> >> >> >> > SE for <class>
>> >> >> >> > class name = motorway_junction
>> >> >> >> > class id = 103
>> >> >> >> > class id = 103 name = motorway_junction added to type
>> name=highway
>> >> >> >> > SE for <class>
>> >> >> >> > class name = trunk
>> >> >> >> > class id = 104
>> >> >> >> > class id = 104 name = trunk added to type name=highway
>> >> >> >> > SE for <class>
>> >> >> >> > class name = trunk_link
>> >> >> >> > class id = 105
>> >> >> >> > class id = 105 name = trunk_link added to type name=highway
>> >> >> >> > SE for <class>
>> >> >> >> > class name = primary
>> >> >> >> > class id = 106
>> >> >> >> > class id = 106 name = primary added to type name=highway
>> >> >> >> > SE for <class>
>> >> >> >> > class name = primary_link
>> >> >> >> > class id = 107
>> >> >> >> > class id = 107 name = primary_link added to type name=highway
>> >> >> >> > SE for <class>
>> >> >> >> > class name = secondary
>> >> >> >> > class id = 106
>> >> >> >> > class id = 106 name = secondary added to type name=highway
>> >> >> >> > SE for <class>
>> >> >> >> > class name = tertiary
>> >> >> >> > class id = 107
>> >> >> >> > class id = 107 name = tertiary added to type name=highway
>> >> >> >> > SE for <class>
>> >> >> >> > class name = residential
>> >> >> >> > class id = 107
>> >> >> >> > class id = 107 name = residential added to type name=highway
>> >> >> >> > SE for <class>
>> >> >> >> > class name = living_street
>> >> >> >> > class id = 108
>> >> >> >> > class id = 108 name = living_street added to type name=highway
>> >> >> >> > SE for <class>
>> >> >> >> > class name = service
>> >> >> >> > class id = 109
>> >> >> >> > class id = 109 name = service added to type name=highway
>> >> >> >> > SE for <class>
>> >> >> >> > class name = track
>> >> >> >> > class id = 110
>> >> >> >> > class id = 110 name = track added to type name=highway
>> >> >> >> > SE for <class>
>> >> >> >> > class name = pedestrian
>> >> >> >> > class id = 111
>> >> >> >> > class id = 111 name = pedestrian added to type name=highway
>> >> >> >> > SE for <class>
>> >> >> >> > class name = services
>> >> >> >> > class id = 112
>> >> >> >> > class id = 112 name = services added to type name=highway
>> >> >> >> > SE for <class>
>> >> >> >> > class name = bus_guideway
>> >> >> >> > class id = 113
>> >> >> >> > class id = 113 name = bus_guideway added to type name=highway
>> >> >> >> > SE for <class>
>> >> >> >> > class name = path
>> >> >> >> > class id = 114
>> >> >> >> > class id = 114 name = path added to type name=highway
>> >> >> >> > SE for <class>
>> >> >> >> > class name = cicleway
>> >> >> >> > class id = 115
>> >> >> >> > class id = 115 name = cicleway added to type name=highway
>> >> >> >> > SE for <class>
>> >> >> >> > class name = footway
>> >> >> >> > class id = 116
>> >> >> >> > class id = 116 name = footway added to type name=highway
>> >> >> >> > SE for <class>
>> >> >> >> > class name = bridleway
>> >> >> >> > class id = 117
>> >> >> >> > class id = 117 name = bridleway added to type name=highway
>> >> >> >> > SE for <class>
>> >> >> >> > class name = byway
>> >> >> >> > class id = 118
>> >> >> >> > class id = 118 name = byway added to type name=highway
>> >> >> >> > SE for <class>
>> >> >> >> > class name = steps
>> >> >> >> > class id = 119
>> >> >> >> > class id = 119 name = steps added to type name=highway
>> >> >> >> > SE for <class>
>> >> >> >> > class name = unclassified
>> >> >> >> > class id = 100
>> >> >> >> > class id = 100 name = unclassified added to type name=highway
>> >> >> >> > SE for <class>
>> >> >> >> > class name = road
>> >> >> >> > class id = 100
>> >> >> >> > class id = 100 name = road added to type name=highway
>> >> >> >> > SE for <type>
>> >> >> >> > SE for <class>
>> >> >> >> > class name = lane
>> >> >> >> > class id = 201
>> >> >> >> > class id = 201 name = lane added to type name=cycleway
>> >> >> >> > SE for <class>
>> >> >> >> > class name = track
>> >> >> >> > class id = 202
>> >> >> >> > class id = 202 name = track added to type name=cycleway
>> >> >> >> > SE for <class>
>> >> >> >> > class name = opposite_lane
>> >> >> >> > class id = 203
>> >> >> >> > class id = 203 name = opposite_lane added to type name=cycleway
>> >> >> >> > SE for <class>
>> >> >> >> > class id = 204
>> >> >> >> > class id = 204 name = opposite added to type name=cycleway
>> >> >> >> > SE for <type>
>> >> >> >> > SE for <class>
>> >> >> >> > class name = grade1
>> >> >> >> > class id = 301
>> >> >> >> > class id = 301 name = grade1 added to type name=tracktype
>> >> >> >> > SE for <class>
>> >> >> >> > class name = grade2
>> >> >> >> > class id = 302
>> >> >> >> > class id = 302 name = grade2 added to type name=tracktype
>> >> >> >> > SE for <class>
>> >> >> >> > class name = grade3
>> >> >> >> > class id = 303
>> >> >> >> > class id = 303 name = grade3 added to type name=tracktype
>> >> >> >> > SE for <class>
>> >> >> >> > class name = grade4
>> >> >> >> > class id = 304
>> >> >> >> > class id = 304 name = grade4 added to type name=tracktype
>> >> >> >> > SE for <class>
>> >> >> >> > class name = grade5
>> >> >> >> > class id = 305
>> >> >> >> > class id = 305 name = grade5 added to type name=tracktype
>> >> >> >> > SE for <type>
>> >> >> >> > SE for <class>
>> >> >> >> > class name = roundabout
>> >> >> >> > class id = 401
>> >> >> >> > class id = 401 name = roundabout added to type name=junction
>> >> >> >> > Trying to load data
>> >> >> >> > Trying to parse data
>> >> >> >> > Kind regards
>> >> >> >> > Eike Lüders
>> >> >> >> > _______________________________________________
>> >> >> >> > Pgrouting-users mailing list
>> >> >> >> > Pgrouting-users at lists.postlbs.org
>> >> >> >> > http://lists.postlbs.org/mailman/listinfo/pgrouting-users
>> >> >> > Neu: GMX Doppel-FLAT mit Internet-Flatrate + Telefon-Flatrate
>> >> >> > für nur 19,99 Euro/mtl.!* http://portal.gmx.net/de/go/dsl02
>> >> > GRATIS für alle GMX-Mitglieder: Die maxdome Movie-FLAT!
>> >> > Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome01
More information about the Pgrouting-users mailing list
