[pgrouting-users] rebuild topology
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Jul 20 09:58:21 EDT 2009
Laura Criscuolo wrote:
> Hi everybody,
> I'm involved in a research on network routing in emergency situations,
> and I need to menage a huge network database, to wich I'm going to add
> and remove roads periodically.
> To rebuild the topology (with the assign_vertex_id function) whenever
> I modify the network takes really plenty of time; do you know a quicker
> way to insert in the topology the new data?
> Thanks in advance!
> Laura
Hi Laura,
assign_vertex_id() function basically iterates through all the edges in
your graph and assigns node number to the source and target columns. So
you could write a function the assigns the source and target node
numbers to a single edge and call that on each new edge you add to the
graph.
Since the source and target numbers are stored on the edges removing the
an edge record will remove it from the graph.
Look at the assign_vertex_id() and it should be pretty straight forward
and obvious as to how to make a new function. Post your questions and
results here and we would be happy to review and/or comment on it.
Best regards,
-Steve
More information about the Pgrouting-users
