[pgrouting-users] Why does shooting star return the last segment
twice?
Stephen Woodbridge
woodbri at swoodbridge.com
Thu May 7 11:07:13 EDT 2009
Any idea why shooting_star would return the last segment twice???
-Steve
routing=# SELECT gid, the_geom
routing-# FROM shooting_star_sp_cd(
routing(# 'st',
routing(# 11213,
routing(# 11218,
routing(# 0.0724637681159,
routing(# 'cost_time',
routing(# 'rcost_time',
routing(# false);
gid |
the_geom
11212 |
0105000020E610000001000000010200000003000000A83BA88CC54B5140782922711A44414058048149C74B51403832B9011F444140B8ECA0B9CF4B5140D84BD5C734444140
33942 |
0105000020E610000001000000010200000002000000F82D2A95B54B514008144FD950444140B8ECA0B9CF4B5140D84BD5C734444140
11217 |
0105000020E610000001000000010200000002000000E06B2FD39E4B514090B0354869444140F82D2A95B54B514008144FD950444140
11218 |
0105000020E610000001000000010200000002000000E8004137864B514068B4ABB383444140E06B2FD39E4B514090B0354869444140
11218 |
(5 rows)
shooting_star_sp_cd() function is just a straight wrapper around your
standard function.
CREATE OR REPLACE FUNCTION shooting_star_sp_cd(
geom_table varchar, sourceid int4, targetid int4, delta float8,
cost_column varchar, rcost_column varchar, dir boolean)
RETURNS SETOF GEOMS AS
DECLARE
path_result record;
geom geoms;
query text;
id integer;
BEGIN
query := generic_sp_query('shortest_path_shooting_star', geom_table,
sourceid, targetid, delta, cost_column, rcost_column, dir);
FOR path_result IN EXECUTE query
LOOP
geom.gid := path_result.gid;
geom.the_geom := path_result.the_geom;
geom.id := id;
RETURN NEXT geom;
END LOOP;
RETURN;
END;
LANGUAGE 'plpgsql' VOLATILE STRICT;
More information about the Pgrouting-users
