[pgrouting-users] Why does shooting star return the last
segment twice?
Anton Patrushev
anton at orkney.co.jp
Thu May 7 20:40:40 EDT 2009
Hi Steve,
This is known issue and it also might also happen with first edge.
It happens because we have two edges for both way streets. For
example, we start (or end) with the edge which is both way streets.
For Shooting* I need to create two edges for both directions with
unique ids (original id for one direction and original id + max id for
reverse direction).
id
id+max_id
So, from the function interface we always get original id for both
start and end. And it might happen that the particular id for one or
both of them is an id for the reverse direction, so it passes the edge
twice - forth and back.
When result is returned, function reduces all ids higher than max_id
to give you original ids. Thus instead of sequence, for example, id ->
id+max_id you have id -> id.
Probably it is worth to add a check to the core Shooting* function
which forms an output sequence (and I actually thought I did it
already). I need to check the source code.
Anton.
On Fri, May 8, 2009 at 12:07 AM, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
> Any idea why shooting_star would return the last segment twice???
> -Steve
> routing=# SELECT gid, the_geom
> routing-# FROM shooting_star_sp_cd(
> routing(# 'st',
> routing(# 11213,
> routing(# 11218,
> routing(# 0.0724637681159,
> routing(# 'cost_time',
> routing(# 'rcost_time',
> routing(# false);
> gid |
> the_geom
> 11212 |
> 0105000020E610000001000000010200000003000000A83BA88CC54B5140782922711A44414058048149C74B51403832B9011F444140B8ECA0B9CF4B5140D84BD5C734444140
> 33942 |
> 0105000020E610000001000000010200000002000000F82D2A95B54B514008144FD950444140B8ECA0B9CF4B5140D84BD5C734444140
> 11217 |
> 0105000020E610000001000000010200000002000000E06B2FD39E4B514090B0354869444140F82D2A95B54B514008144FD950444140
> 11218 |
> 0105000020E610000001000000010200000002000000E8004137864B514068B4ABB383444140E06B2FD39E4B514090B0354869444140
> 11218 |
> (5 rows)
> shooting_star_sp_cd() function is just a straight wrapper around your
> standard function.
> CREATE OR REPLACE FUNCTION shooting_star_sp_cd(
> geom_table varchar, sourceid int4, targetid int4, delta float8,
> cost_column varchar, rcost_column varchar, dir boolean)
> RETURNS SETOF GEOMS AS
> DECLARE
> path_result record;
> geom geoms;
> query text;
> id integer;
> BEGIN
> query := generic_sp_query('shortest_path_shooting_star', geom_table,
> sourceid, targetid, delta, cost_column, rcost_column, dir);
> FOR path_result IN EXECUTE query
> LOOP
> geom.gid := path_result.gid;
> geom.the_geom := path_result.the_geom;
> geom.id := id;
> RETURN NEXT geom;
> END LOOP;
> RETURN;
> END;
> LANGUAGE 'plpgsql' VOLATILE STRICT;
> Pgrouting-users mailing list
> Pgrouting-users at lists.postlbs.org
> http://lists.postlbs.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
