[pgrouting-users] assign_vertex_id missing
Stefan Gasser stefan.gasser at r3-gis.com
Tue Nov 3 03:14:34 EST 2009
Hi Flavio,
open your Database.
In the Schema "public" there are the functions.
Maybe the datatypes are wrong or your geometry column is not in the
table geometry_columns?
Regards
Stefan
Am Dienstag, den 03.11.2009, 09:02 +0100 schrieb flavio rigolon:
> Hi list,
>  this is my first post in this ml: sorry in advance for the newbye
> question.
> I'm running on Debian (Lenny) and following this instructions
> ( http://pgrouting.postlbs.org/wiki/1.x/MakeDebPackage ) I installed
> the package "postgresql-8.3-pgrouting".
> Then I create a db with spatial extension (lwpostgis.sql and
> spatial_ref_sys.sql) and then with pgrouting extension
> (routing_core.sql and routing_core_wrappers.sql). All fine.
> After importing data (via shp2pgsql) I try to create topology with the
> "assign_vertex_id" function but I get this:
> "ERROR:  function assign_vertex_id(unknown, numeric, unknown, unknown)
> does not exist"
> Infact, browsing the database via pgadmin3, I cannot see this
> function.
> Is this function deprecated? Or the debian installer missing it? Is
> there another way to build the topology?
> Thanks in advance for any hints
> ciao
> flavio
> Linux, perche' no? Io uso debian.
> Pgrouting-users mailing list
> Pgrouting-users at lists.postlbs.org
> http://lists.postlbs.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
