[pgrouting-users] Direction for path
poonam jalwan
poonam.jalwan at orkash.com
Wed Oct 14 05:43:37 EDT 2009
Can u explain me how u implement direction of shortest path in
application.What is minimum requirement of data.
like my data structure is :-
CREATE TABLE india_roads
gid serial NOT NULL,
med_descri character varying(254),
rtt_descri character varying(254),
f_code_des character varying(10),
iso character varying(7),
isocountry character varying(54),
the_geom geometry,
source integer,
target integer,
length double precision,
"cost" double precision,
id integer NOT NULL DEFAULT nextval('india_roads_gid_seq'::regclass),
CONSTRAINT india_roads_pkey PRIMARY KEY (gid),
CONSTRAINT enforce_dims_the_geom CHECK (ndims(the_geom) = 2),
CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
'MULTILINESTRING'::text OR the_geom IS NULL),
CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = 4326)
WITH (OIDS=FALSE);
ALTER TABLE india_roads OWNER TO postgres;
GRANT ALL ON TABLE india_roads TO postgres;
GRANT SELECT ON TABLE india_roads TO public;
Finding direction of shortest path is possible on my dataset..
Thanks
Poonam
Stephen Woodbridge wrote:
> poonam jalwan wrote:
>> Hi All,
>> I am using pgrouting functions for finding shortest path from point
>> A to point B,Now i want to find the direction of shortest path and
>> multiple path from point A to point B.Please anyone help which
>> function of pgrouting i have to use.
> When you say "direction of shortest path" are you referring to human
> readable text driving directions?
> If so there currently is no function in pgRouting that does that. I
> have discussed this in some detail on the list (check the archives),
> and how it can be implemented. I have implemented this:
> http://imaptools.com:8080/maps/dd2.html?lat=34.53886&lon=69.15786&zoom=13&layers=B00TFTTTF&start=69.144741%2034.547085&stop=69.172264%2034.531735&method=STS&lang=eng
> but is dependent on the structure of the data tables you load and use.
> There is a lot more information in the archives explain how this was
> done.
> -Steve
More information about the Pgrouting-users
