[pgrouting-users] install problem on SLES 11 x86_64
Christian Grau
ch.grau at gmx.de
Fri Sep 11 11:56:13 EDT 2009
hi list,
sorry for my bad english :-)
i'm trying installing pgrouting on sles 11 64 BIT
boost 1.36 is OK
CGAL 3.3.1 is OK
CMAKE 2.6.4 is OK
but pgrouting 1.0.3 gets an error after make VERBOSE=1 i get:
/usr/local/bin/cmake -H/usr/local/src/pgrouting -B/usr/local/src/pgrouting --check-build-system CMakeFiles/Makefile.cmake 0
/usr/local/bin/cmake -E cmake_progress_start /usr/local/src/pgrouting/CMakeFiles /usr/local/src/pgrouting/CMakeFiles/progress.make
make -f CMakeFiles/Makefile2 all
make[1]: Entering directory `/usr/local/src/pgrouting'
make -f core/src/CMakeFiles/routing.dir/build.make core/src/CMakeFiles/routing.dir/depend
make[2]: Entering directory `/usr/local/src/pgrouting'
cd /usr/local/src/pgrouting && /usr/local/bin/cmake -E cmake_depends "Unix Makefiles" /usr/local/src/pgrouting /usr/local/src/pgrouting/core/src /usr/local/src/pgrouting /usr/local/src/pgrouting/core/src /usr/local/src/pgrouting/core/src/CMakeFiles/routing.dir/DependInfo.cmake --color=
make[2]: Leaving directory `/usr/local/src/pgrouting'
make -f core/src/CMakeFiles/routing.dir/build.make core/src/CMakeFiles/routing.dir/build
/usr/local/bin/cmake -E cmake_progress_report /usr/local/src/pgrouting/CMakeFiles 1
[ 16%] Building C object core/src/CMakeFiles/routing.dir/dijkstra.o
cd /usr/local/src/pgrouting/core/src && /usr/bin/gcc -Drouting_EXPORTS -O2 -g -fPIC -I/usr/local/pgsql/include/server -I/usr/local/src/pgrouting/core/src -I/usr/local/src/pgrouting/. -I/usr/local/src/pgrouting/core -I/usr/local/src/pgrouting/extra -I/usr/local/src/pgrouting/extra/tsp -I/usr/local/src/pgrouting/extra/tsp/src -I/usr/local/src/pgrouting/extra/driving_distance -I/usr/local/src/pgrouting/extra/driving_distance/src -o CMakeFiles/routing.dir/dijkstra.o -c /usr/local/src/pgrouting/core/src/dijkstra.c
/usr/local/src/pgrouting/core/src/dijkstra.c: In function âfetch_edge_columnsâ:
/usr/local/src/pgrouting/core/src/dijkstra.c:98: error: âINT4OIDâ undeclared (first use in this function)
/usr/local/src/pgrouting/core/src/dijkstra.c:98: error: (Each undeclared identifier is reported only once
/usr/local/src/pgrouting/core/src/dijkstra.c:98: error: for each function it appears in.)
/usr/local/src/pgrouting/core/src/dijkstra.c:100: error: âFLOAT8OIDâ undeclared (first use in this function)
make[2]: *** [core/src/CMakeFiles/routing.dir/dijkstra.o] Error 1
make[1]: *** [core/src/CMakeFiles/routing.dir/all] Error 2
make[1]: Leaving directory `/usr/local/src/pgrouting'
make: *** [all] Error 2
can you help me please
thanks
christian
Neu: GMX Doppel-FLAT mit Internet-Flatrate + Telefon-Flatrate
für nur 19,99 Euro/mtl.!* http://portal.gmx.net/de/go/dsl02
More information about the Pgrouting-users
