[pgrouting-users] where is assign_vertex_id?
Milo van der Linden milo at dogodigi.net
Thu Sep 17 07:28:56 EDT 2009
Hi there,
I did a fresh install of pgrouting 1.0.3 and am currently setting up my
data tables.
I try to run:
SELECT assign_vertex_id('ways', 0.00001, 'the_geom', 'gid');
But it turns out this function does not exist.
ERROR:  function assign_vertex_id(unknown, numeric, unknown, unknown)
does not exist
LINE 24: SELECT assign_vertex_id('ways', 0.00001, 'the_geom', 'gid');
HINT:  No function matches the given name and argument types. You might
need to add explicit type casts.
If I want the function, what should I do? Or can I do something else?
Are source and target nodeid's or id's of adjacent edges?
Thank you for answering,
Kind regards,
Milo van der Linden
More information about the Pgrouting-users mailing list
