[pgrouting-users] where is assign_vertex_id?
Milo van der Linden
milo at dogodigi.net
Thu Sep 17 07:53:06 EDT 2009
Sorry for posting.
I found the documentation does not describe installing the topology.sql
I also needed to fix my table into the geometry_columns table otherwise
assign_vertex_id throws an error. You can easily do this useing select
probe_geometry_columns()
Thanks! I now have my first rough routing
Milo van der Linden schreef:
> Hi there,
> I did a fresh install of pgrouting 1.0.3 and am currently setting up my
> data tables.
> I try to run:
> SELECT assign_vertex_id('ways', 0.00001, 'the_geom', 'gid');
> But it turns out this function does not exist.
> ERROR: function assign_vertex_id(unknown, numeric, unknown, unknown)
> does not exist
> LINE 24: SELECT assign_vertex_id('ways', 0.00001, 'the_geom', 'gid');
> HINT: No function matches the given name and argument types. You might
> need to add explicit type casts.
> If I want the function, what should I do? Or can I do something else?
> Are source and target nodeid's or id's of adjacent edges?
> Thank you for answering,
> Kind regards,
> Milo van der Linden
> Pgrouting-users mailing list
> Pgrouting-users at lists.postlbs.org
> http://lists.postlbs.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
