[pgrouting-users] Data prep questions
Charles Galpin
cgalpin at lhsw.com
Fri Feb 19 09:33:15 EST 2010
Hi All
I am trying to use pgrouting with navteq streets data (NJ, USA) imported from shape files. I am not getting good results and believe it might be due to the way the data is setup.
Do the start and end points of the geometry need to be oriented the same way? For example if you had 3 sequential segments A,B,C does it have to look like this
x1,y1 ---- A ---- x2,y2 == x1,y1 ---- B ---- x2,y2 == x1,y1 ---- C ---- x2,y2
Or could it be something like this and still work properly for example?
x1,y1 ---- A ---- x2,y2 == x2,y2 ---- B ---- x1,y1 == x1,y1 ---- C ---- x2,y2
The reason I ask is because the navteq segments can be this second case because of the way the data is structured and I need to know if I should try and rectify this.
thanks,
charles
More information about the Pgrouting-users
