[pgrouting-users] Problems recalculating the network topology
Peter Hopfgartner
peter.hopfgartner at r3-gis.com
Thu Jul 8 11:19:04 EDT 2010
Dear pgRouting tribe!
I would like to run assign_vertex_id() for a simple table, like the
following:
CREATE TABLE dhl_ret_l
gid integer NOT NULL,
the_geom geometry,
source integer,
target integer,
length double precision,
"cluster" integer,
CONSTRAINT dhl_ret_l_pkey PRIMARY KEY (gid),
CONSTRAINT enforce_dims_the_geom CHECK (st_ndims(the_geom) = 2),
CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
'LINESTRING'::text OR the_geom IS NULL),
CONSTRAINT enforce_srid_the_geom CHECK (st_srid(the_geom) = 3003)
This is fine for the first time. Now I would like to recalculate the
network topology, so I do:
SELECT DropGeometryColumn('public', 'vertices_tmp', 'the_geom');
DROP TABLE vertices_tmp;
and try to restart the calculation:
SELECT assign_vertex_id('dhl_ret_l', 0.00, 'the_geom', 'gid');
and get the following error:
NOTICE: CREATE TABLE will create implicit sequence
"vertices_tmp_id_seq" for serial column "vertices_tmp.id"
CONTEXT: SQL statement "CREATE TABLE vertices_tmp (id serial)"
PL/pgSQL function "assign_vertex_id" line 14 at execute statement
CONTEXT: PL/pgSQL function "assign_vertex_id" line 29 at assignment
ERROR: relation with OID 5843275 does not exist
CONTEXT: SQL statement "SELECT
Distance(the_geom,GeometryFromText( AsText( $1 ), $2 )) AS d, id,
the_geom FROM vertices_tmp WHERE the_geom &&
Expand(GeometryFromText(AsText( $1 ), $2 ), $3 ) AND
Distance(the_geom, GeometryFromText(AsText( $1 ), $2 )) < $3 ORDER BY
d LIMIT 1"
PL/pgSQL function "point_to_id" line 13 at SQL statement
What am I doing wrongly?
Regards,
Peter
Dott. Peter Hopfgartner
R3 GIS Srl - GmbH
Via Johann Kravogl-Str. 2
I-39012 Meran/Merano (BZ)
Email: peter.hopfgartner at r3-gis.com
Tel. : +39 0473 494949
Fax : +39 0473 069902
www : http://www.r3-gis.com
XING : http://www.xing.com/go/invita/8917535
More information about the Pgrouting-users
